Rockbox: PictureFlow plugin autostarts at boot
Posted: Wed Sep 21, 2011 7:27 pm
Since a few days I'm using Rockbox (an open source firmware for mp3 players) as OS for my almost 2 year old Sansa Clip+ player.
Everything's great, but all over a sudden it showed the following message for a few seconds after startup:
hmpf. I've never configured or asked it to do so
I couldn't find any setting or configuration option that I could use to disable the pictureflow autostart.
So I simply opened the rockbox configuration file and found the line:
According to the Rockbox documentation, the following values are allowed:
I've set it to "WPS" in order to display the playback screen after bootup:
NOTE: Thanks to the awesomeness of Rockbox, I was able to do this completely on the player device - without using my PC to edit the config file! Wow!
...and then it automatically started the "PictureFlow" plugin.Database is not ready
That's it! You simply have to change that option to something else.start in screen: pictureflow
previous, root, files, dB, wps, menu, recording, radio, bookmarks
start in screen: wps
