If you're dealing with input strings in bash which contain special characters like spaces " ", brackets "(", etc... - it's necessary to escape those characters.
For example, if you'd try to call a script and pass it a string as argument which contains special characters, like this:
it won't be enough to read it like this:./myscript "my test file (1).txt"
FILENAME="$1"[SOLUTION]
FILENAME=$(printf '%q' "$1")my\ test\ file\ \(1\).txt
