Rename LVM volume group
Since I've been following instructions on how to setup LVMs on my machines, each LVM on each different computer had the same volume group name: "lvmvolume".
So far so good, but one day I had to mount an LVM partition from another machine, and suddenly "pvscan" showed me 2 LVM volume groups - BUT: both had the same name "lvmvolume" :(
Now "lvscan" (and any other tool accessing the logical volumes) only accessed the first volume group, and it was impossible for the system to distinguish them.
You have to rename the volume group of any of those LVMs in order to be able to distinguishably address them.
Problem: It's hard, dangerous (and maybe impossible) to do so on a machine with the same volume group name in use.
So, I've mounted one of the drives on another computer which did *not* have any LVM configured, and did the following to rename the volume group:
Run "pvscan" to see if the LVM volume group shows up:
sudo pvscan
The result in my case looked like this:
PV /dev/sdc2 VG lvmvolume lvm2 [148.94 GB / 0 free]
Total: 1 [148.94 GB] / in use: 1 [148.94 GB] / in no VG: 0 [0 ]
Now, make sure that that all logical volumes in that group are inactive, by disabling them:
sudo lvchange -an lvmvolume
Then use "vgrename" to do the actual name change:
sudo vgrename <old_name> <new_name>
In my case, I chose to use some sort of ID for the new name to avoid future conflicts with other LVMs:
sudo vgrename lvmvolume lvm_160_pc1
("160" for the size in GB - and "PC1" for the server name. However, that naming is completely arbitrary)
