Mac-formatted harddisk: Unreadable partition table?
Posted: Mon Apr 02, 2012 12:28 pm
I've received an external USB drive, claiming to have 4 partitions.
At least that's what /dev says:
It should only have had 1, so I tried to run "fdisk", but was greeted with another, interesting message:
The output of "dmesg" slightly confirms my assumption that this disk has been re-formatted on a Mac:
The interesting line here being:
was unsuccessful:
Again, unsuccessfully:
I haven't been able to read the partition table to find out which partition is which, but I've successfully mounted partitions.
It seemed that the first two (sdc1, sdc2) and the last one (sdc4) are "something else" - and not HFS+.
Mounting /dev/sdc3 worked:
I didn't even have to specificy "-t hfsplus".
Not perfect, but at least usable...
brw-rw---- 1 root floppy 8, 32 2012-04-02 11:44 /dev/sdc
brw-rw---- 1 root floppy 8, 33 2012-04-02 11:44 /dev/sdc1
brw-rw---- 1 root floppy 8, 34 2012-04-02 11:44 /dev/sdc2
brw-rw---- 1 root floppy 8, 35 2012-04-02 11:44 /dev/sdc3
brw-rw---- 1 root floppy 8, 36 2012-04-02 11:44 /dev/sdc4
Plugging the drive into a Windows7 machine, Windows told me that it had to initialize the drive before being able to use it.Device contains neither a valid DOS partition table, nor Sun, SGI or OSF disklabel
Building a new DOS disklabel with disk identifier 0x72a2763b.
Changes will remain in memory only, until you decide to write them.
After that, of course, the previous content won't be recoverable.
[1720533.501332] Initializing USB Mass Storage driver...
[1720533.501415] scsi4 : SCSI emulation for USB Mass Storage devices
[1720533.501483] usb-storage: device found at 5
[1720533.501484] usb-storage: waiting for device to settle before scanning
[1720533.501493] usbcore: registered new interface driver usb-storage
[1720533.501528] USB Mass Storage support registered.
[1720538.518664] usb-storage: device scan complete
[1720538.554897] scsi 4:0:0:0: Direct-Access ST950032 5AS 0002 PQ: 0 ANSI: 5
[1720538.642475] sd 4:0:0:0: [sdc] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[1720538.929720] sd 4:0:0:0: [sdc] Write Protect is off
[1720538.929755] sd 4:0:0:0: [sdc] Mode Sense: 23 00 00 00
[1720538.929759] sd 4:0:0:0: [sdc] Assuming drive cache: write through
[1720539.428995] sd 4:0:0:0: [sdc] Assuming drive cache: write through
[1720539.429034] sdc: [mac] sdc1 sdc2 sdc3 sdc4
[1720540.331641] sd 4:0:0:0: [sdc] Assuming drive cache: write through
[1720540.331679] sd 4:0:0:0: [sdc] Attached SCSI disk
Trying to mount one of the partitions inspite of fdisk's output:[1720539.429034] sdc: [mac] sdc1 sdc2 sdc3 sdc4
sudo mount /dev/sdc1 /mnt/usb
Ok, so I tried again with "-t hfsplus":mount: you must specify the filesystem type
sudo mount /dev/sdc1 -t hfsplus /mnt/usb
Dmesg said:mount: wrong fs type, bad option, bad superblock on /dev/sdc1,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
[SOLUTION][1724183.567124] attempt to access beyond end of device
[1724183.567160] sdc1: rw=0, want=262211, limit=63
[1724183.567189] hfs: unable to find HFS+ superblock
sudo mount /dev/sdc3 /mnt/usb
