Intel DH67BL and Ubuntu Oneiric: Audio problems
Posted: Mon Apr 09, 2012 8:30 pm
I've experienced a very, very weird behavior of my sound output when running Ubuntu Oneiric (11.10):
The rear audio output turned itself off every once in a while. It only worked about 5 minutes per hour or so... hmpf.
When the problem appeared, the volume faders started trembling (no matter in which application: From XFCE's Mixer to Alsaconf - and even the volume indicator plugin), and the mute state was flickering on/off.
Scary...
I first suspected a hardware problem, but then I plugged earphones into the front audio out, and interesting:
The front audio worked all the time!
Another interesting thing:
The problems started after enabling the front audio in the BIOS. I've currently set it to "Legacy" (instead of "Auto" or "High Definition".
One solution is probably to disable the front audio panel in the BIOS, but I've figured out a weird behavior-connection between audio channels which currently seems to enable me to re-enable the rear output:
The "Headphone" output!
Togging mute/unmute of the Headphone output in XFCE's mixer (or alsamixer) suddenly turned the rear-audio back on.
However, there's a small inconsistency:
When unmuting Master and Headphone in XFCE's mixer (Device: HDA Intel PCH (Alsa mixer)), it's not enough:
The volume indicator plugin still showed the master being mute. I've clicked the indicator plugin, selected "unmute" and the sound was back.
Weird...
Additionally:
Unmuting in alsamixer (or XFCE's mixer is not enough), *but* turning the volume up to the max of Master and Headphone, actually unmuted it.
Scary...
Weird...
Additionally:
