Samba: Error connecting to socket. Return code -115
Posted: Mon Dec 03, 2012 2:29 pm
I'm trying to connect to Windows DFS once again, and as usual it's a little princess with special needs:
Thanks to an article on Pragmatic IT, titled "Connecting to DFS Shares with Ubuntu", I found a solution:
[SOLUTION][ 22.784021] CIFS VFS: Error connecting to socket. Aborting operation
[ 22.784086] CIFS VFS: cifs_mount failed w/return code = -115
- Install "keyutils":
$ sudo apt-get install keyutils - Add the following 2 lines in /etc/request-key.conf:
create cifs.spnego * * /usr/sbin/cifs.upcall -c %k %d create dns_resolver * * /usr/sbin/cifs.upcall %k
