Find duplicate files using MD5SUMS plaintext files
Posted: Tue Jan 22, 2013 4:41 pm
md5sum ... > list_1.txt
md5sum ... > list_2.txt
Then you must replace the " " between the columns (MD5, filename) with a ";" to be able to use "cut" to parse the columns.
#!/bin/bash
LIST_1="$1"
LIST_2="$2"
while read LINE; do
#echo "Line: $LINE"
CHECKSUM_1=$(echo $LINE | cut -d\; -f1)
FILENAME_1=$(echo $LINE | cut -d\; -f2)
MATCH=$(cat "$LIST_2" | grep "$CHECKSUM_1")
if [ ! -z "$MATCH" ]; then
CHECKSUM_MATCH=$(echo $MATCH | cut -d\; -f1)
FILENAME_MATCH=$(echo $MATCH | cut -d\; -f2)
echo "MATCH: "
echo " $CHECKSUM_1 ($FILENAME_1)"
echo " $CHECKSUM_MATCH ($FILENAME_MATCH)"
fi
done < $LIST_1
