Backblaze Pod 2.0
Posted: Tue Jul 30, 2013 5:52 pm
This thread contains some information about setting up a Backblaze Storage Pod v2.0 - and some numbers about its performance, etc.
The system was set up as follows:
  • RedHat Enterprise Linux Server x86_64 v6
  • 3x RAID6 with 15 disks each
  • Default hardware, as supplied by Protocase: SuperMicro board, Intel i3@3.1GHz with 8GB RAM
RAID initialization rates:
Personalities : [raid6] [raid5] [raid4]
md2 : active raid6 sdy[8] sdz[9] sdan[13] sdg[0] sdk[4] sdv[5] sdi[2] sdw[6] sdx[7] sdao[14] sdak[
10] sdh[1] sdal[11] sdam[12] sdj[3]
      38091755520 blocks super 1.2 level 6, 512k chunk, algorithm 2 [15/15] [UUUUUUUUUUUUUUU]
      [>....................]  resync =  2.4% (73209600/2930135040) finish=3413.6min speed=13947K/
sec
md0 : active raid6 sds[7] sdd[2] sdt[8] sdag[11] sdu[9] sdr[6] sdaj[14] sdai[13] sdq[5] sdaf[10] s
de[3] sdah[12] sdb[0] sdf[4] sdc[1]
      [>....................]  resync =  2.4% (71764480/2930135040) finish=3369.5min speed=14137K/
sec
md3 : active raid6 sdae[9] sdad[8] sdaq[11] sdaa[5] sdab[6] sdo[3] sdas[13] sdl[0] sdac[7] sdat[14
] sdn[2] sdm[1] sdar[12] sdp[4] sdap[10]
      [>....................]  resync =  2.4% (73110280/2930135040) finish=3663.7min speed=12996K/
sec
RAM benchmarks:
1) Using "dd" with a pipe:
dd if=/dev/zero bs=1G count=1 | dd bs=1G of=/dev/null
1+0 records in
1+0 records out
1+0 records in
1+0 records out
1073741824 bytes (1.1 GB) copied1073741824 bytes (1.1 GB) copied, 1.25197 s, 858 MB/s
, 1.25363 s, 857 MB/s
2) "dd" without pipe:
dd if=/dev/zero bs=1G count=1 of=/dev/null
1+0 records in
1+0 records out
1073741824 bytes (1.1 GB) copied, 0.247495 s, 4.3 GB/s
Listing which drive is connected where...
Posted: Tue Jul 30, 2013 5:56 pm
Here's a minimal BASH script for creating a text listing that shows all hardware information about all the storage-drives in a Backblaze Pod:
INFO_FILE="hdd_info.txt"
date > $INFO_FILE
for DISK in /dev/disk/by-path/pci-0000:0[246]*; do
        echo "Disk: $DISK"
        hdparm -I $DISK >> $INFO_FILE
done
This can be used to identify which harddisks are connected to which backplane, controller and PSU.
It's also quite handy to have this list for replacing failed drives, because there's no indicator LED. Therefore you can use the drive's serial number.
lspci output
Posted: Fri Aug 02, 2013 1:07 am
The output of "lspci -vv": I know it's lengthy, and maybe boring for some, but I post this here for others to compare, in case they need it.
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
        Subsystem: Super Micro Computer Inc Device 0624
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
        Latency: 0
        Capabilities: [e0] Vendor Specific Information: Len=0c <?>
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09) (prog-if 00 [Normal decode])
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0, Cache Line Size: 64 bytes
        Bus: primary=00, secondary=01, subordinate=02, sec-latency=0
        I/O behind bridge: 0000e000-0000efff
        Memory behind bridge: dfd00000-dfdfffff
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
        BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
                PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
        Capabilities: [88] Subsystem: Super Micro Computer Inc Device 0624
        Capabilities: [80] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
                Address: fee0f00c  Data: 4189
        Capabilities: [a0] Express (v2) Root Port (Slot+), MSI 00
                DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
                        ExtTag- RBE+ FLReset-
                DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
                        RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
                        MaxPayload 128 bytes, MaxReadReq 128 bytes
                DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
                LnkCap: Port #2, Speed 5GT/s, Width x8, ASPM L0s L1, Latency L0 <256ns, L1 <4us
                        ClockPM- Surprise- LLActRep- BwNot+
                LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk+
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt+ ABWMgmt-
                SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
                        Slot #1, PowerLimit 75.000W; Interlock- NoCompl+
                SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
                        Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
                SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
                        Changed: MRL- PresDet- LinkState-
                RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna- CRSVisible-
                RootCap: CRSVisible-
                RootSta: PME ReqID 0000, PMEStatus- PMEPending-
                DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR+, OBFF Not Supported ARIFwd-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
                LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
                         Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
                         Compliance De-emphasis: -6dB
                LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
                         EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
        Capabilities: [100 v1] Virtual Channel
                Caps:   LPEVC=0 RefClk=100ns PATEntryBits=1
                Arb:    Fixed- WRR32- WRR64- WRR128-
                Ctrl:   ArbSelect=Fixed
                Status: InProgress-
                VC0:    Caps:   PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
                        Arb:    Fixed+ WRR32- WRR64- WRR128- TWRR128- WRR256-
                        Ctrl:   Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
                        Status: NegoPending- InProgress-
        Capabilities: [140 v1] Root Complex Link
                Desc:   PortNumber=02 ComponentID=01 EltType=Config
                Link0:  Desc:   TargetPort=00 TargetComponent=01 AssocRCRB- LinkType=MemMapped LinkValid+
                        Addr:   00000000fed19000
        Kernel driver in use: pcieport
        Kernel modules: shpchp
00:01.1 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09) (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=03, subordinate=04, sec-latency=0
        I/O behind bridge: 0000d000-0000dfff
        Memory behind bridge: dfc00000-dfcfffff
                Address: fee0f00c  Data: 4191
                LnkCap: Port #3, Speed 5GT/s, Width x8, ASPM L0s L1, Latency L0 <256ns, L1 <4us
                        Slot #2, PowerLimit 75.000W; Interlock- NoCompl+
                Status: InProgress-
                Desc:   PortNumber=03 ComponentID=01 EltType=Config
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05) (prog-if 20 [EHCI])
        Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Interrupt: pin A routed to IRQ 16
        Region 0: Memory at dfe04000 (32-bit, non-prefetchable) [size=1K]
        Capabilities: [50] Power Management version 2
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
                Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [58] Debug port: BAR=1 offset=00a0
        Capabilities: [98] PCI Advanced Features
                AFCap: TP+ FLR+
                AFCtrl: FLR-
                AFStatus: TP-
        Kernel driver in use: ehci_hcd
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5) (prog-if 00 [Normal decode])
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Bus: primary=00, secondary=05, subordinate=06, sec-latency=0
        I/O behind bridge: 0000c000-0000cfff
        Memory behind bridge: dfb00000-dfbfffff
        Capabilities: [40] Express (v2) Root Port (Slot+), MSI 00
                DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
                LnkCap: Port #1, Speed 5GT/s, Width x4, ASPM L0s L1, Latency L0 <512ns, L1 <4us
                        ClockPM- Surprise- LLActRep+ BwNot-
                LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
                        Slot #0, PowerLimit 25.000W; Interlock- NoCompl+
                DevCap2: Completion Timeout: Range BC, TimeoutDis+, LTR-, OBFF Not Supported ARIFwd-
                LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
        Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
                Address: 00000000  Data: 0000
        Capabilities: [90] Subsystem: Super Micro Computer Inc Device 0624
        Capabilities: [a0] Power Management version 2
00:1c.4 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 5 (rev b5) (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
        I/O behind bridge: 0000b000-0000bfff
        Memory behind bridge: dfa00000-dfafffff
                DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
                LnkCap: Port #5, Speed 5GT/s, Width x1, ASPM L0s L1, Latency L0 <512ns, L1 <4us
                        Slot #4, PowerLimit 10.000W; Interlock- NoCompl+
00:1c.6 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 7 (rev b5) (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=08, subordinate=08, sec-latency=0
        I/O behind bridge: 0000a000-0000afff
        Memory behind bridge: df900000-df9fffff
                LnkCap: Port #7, Speed 5GT/s, Width x1, ASPM L0s L1, Latency L0 <512ns, L1 <4us
                        Slot #6, PowerLimit 10.000W; Interlock- NoCompl+
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05) (prog-if 20 [EHCI])
        Latency: 0
        Interrupt: pin A routed to IRQ 23
        Region 0: Memory at dfe03000 (32-bit, non-prefetchable) [size=1K]
                AFCap: TP+ FLR+
                AFCtrl: FLR-
                AFStatus: TP-
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a5) (prog-if 01 [Subtractive decode])
        Latency: 0
        Bus: primary=00, secondary=09, subordinate=09, sec-latency=64
        Memory behind bridge: df000000-df8fffff
        Prefetchable memory behind bridge: 00000000de000000-00000000deffffff
        Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
        BridgeCtl: Parity- SERR- NoISA- VGA+ MAbort- >Reset- FastB2B-
        Capabilities: [50] Subsystem: Super Micro Computer Inc Device 0624
00:1f.0 ISA bridge: Intel Corporation C202 Chipset Family LPC Controller (rev 05)
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Kernel modules: iTCO_wdt
00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family SATA AHCI Controller (rev 05) (prog-if 01 [AHCI 1.0])
        Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Interrupt: pin B routed to IRQ 30
        Region 0: I/O ports at f050 [size=8]
        Region 1: I/O ports at f040 [size=4]
        Region 2: I/O ports at f030 [size=8]
        Region 3: I/O ports at f020 [size=4]
        Region 4: I/O ports at f000 [size=32]
        Region 5: Memory at dfe02000 (32-bit, non-prefetchable) [size=2K]
        Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
                Address: fee0500c  Data: 41a1
        Capabilities: [70] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot+,D3cold-)
        Capabilities: [a8] SATA HBA v1.0 BAR4 Offset=00000004
        Capabilities: [b0] PCI Advanced Features
                AFCap: TP+ FLR+
                AFCtrl: FLR-
                AFStatus: TP-
        Kernel driver in use: ahci
        Kernel modules: ahci
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 05)
        Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Interrupt: pin C routed to IRQ 18
        Region 0: Memory at dfe01000 (64-bit, non-prefetchable) [size=256]
        Region 4: I/O ports at 0580 [size=32]
        Kernel modules: i2c-i801
01:00.0 PCI bridge: Pericom Semiconductor Device e111 (rev 02) (prog-if 00 [Normal decode])
        Bus: primary=01, secondary=02, subordinate=02, sec-latency=64
        Secondary status: 66MHz+ FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- <SERR- <PERR-
        Capabilities: [80] PCI-X bridge device
                Secondary Status: 64bit- 133MHz- SCD- USC- SCO- SRD- Freq=conv
                Status: Dev=01:00.0 64bit- 133MHz- SCD+ USC- SCO+ SRD-
                Upstream: Capacity=16 CommitmentLimit=16
                Downstream: Capacity=16 CommitmentLimit=16
        Capabilities: [90] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=55mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
        Capabilities: [a8] Subsystem: Gammagraphx, Inc. (or missing ID) Device 0000
        Capabilities: [b0] Express (v1) PCI/PCI-X Bridge, MSI 00
                DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
                        ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
                        RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop- BrConfRtry-
                        MaxPayload 128 bytes, MaxReadReq 512 bytes
                DevSta: CorrErr+ UncorrErr+ FatalErr- UnsuppReq+ AuxPwr+ TransPend-
                LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <512ns, L1 <1us
                        ClockPM- Surprise- LLActRep- BwNot-
                LnkCtl: ASPM Disabled; Disabled- Retrain- CommClk+
                LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
        Capabilities: [f0] MSI: Enable- Count=1/1 Maskable- 64bit+
                Address: 0000000000000000  Data: 0000
        Capabilities: [100 v1] Advanced Error Reporting
                UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
                CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
                AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
        Capabilities: [150 v1] Virtual Channel
                Status: InProgress-
                        Arb:    Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
                        Ctrl:   Enable+ ID=0 ArbSelect=Fixed TC/VC=01
02:04.0 RAID bus controller: Silicon Image, Inc. SiI 3124 PCI-X Serial ATA Controller (rev 02)
        Subsystem: Silicon Image, Inc. Device 7124
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping+ SERR- FastB2B- DisINTx-
        Latency: 64, Cache Line Size: 64 bytes
        Region 0: Memory at dfd88000 (64-bit, non-prefetchable) [size=128]
        Region 2: Memory at dfd80000 (64-bit, non-prefetchable) [size=32K]
        Region 4: I/O ports at e000 [size=16]
        Expansion ROM at dfd00000 [disabled] [size=512K]
        Capabilities: [64] Power Management version 2
                Flags: PMEClk- DSI+ D1+ D2+ AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
                Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=1 PME-
        Capabilities: [40] PCI-X non-bridge device
                Command: DPERE- ERO+ RBC=512 OST=12
                Status: Dev=ff:1f.0 64bit+ 133MHz+ SCD- USC- DC=simple DMMRBC=2048 DMOST=12 DMCRS=128 RSCEM- 266MHz- 533MHz-
        Capabilities: [54] MSI: Enable- Count=1/1 Maskable- 64bit+
        Kernel driver in use: sata_sil24
        Kernel modules: sata_sil24
03:00.0 PCI bridge: Pericom Semiconductor Device e111 (rev 02) (prog-if 00 [Normal decode])
        Bus: primary=03, secondary=04, subordinate=04, sec-latency=64
                Status: Dev=03:00.0 64bit- 133MHz- SCD+ USC- SCO+ SRD-
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
                Status: InProgress-
04:04.0 RAID bus controller: Silicon Image, Inc. SiI 3124 PCI-X Serial ATA Controller (rev 02)
        Interrupt: pin A routed to IRQ 17
        Region 0: Memory at dfc88000 (64-bit, non-prefetchable) [size=128]
        Region 2: Memory at dfc80000 (64-bit, non-prefetchable) [size=32K]
        Region 4: I/O ports at d000 [size=16]
        Expansion ROM at dfc00000 [disabled] [size=512K]
05:00.0 PCI bridge: Pericom Semiconductor Device e111 (rev 02) (prog-if 00 [Normal decode])
        Bus: primary=05, secondary=06, subordinate=06, sec-latency=64
                Status: Dev=05:00.0 64bit- 133MHz- SCD+ USC- SCO+ SRD-
                Status: InProgress-
06:04.0 RAID bus controller: Silicon Image, Inc. SiI 3124 PCI-X Serial ATA Controller (rev 02)
        Region 0: Memory at dfb88000 (64-bit, non-prefetchable) [size=128]
        Region 2: Memory at dfb80000 (64-bit, non-prefetchable) [size=32K]
        Region 4: I/O ports at c000 [size=16]
        Expansion ROM at dfb00000 [disabled] [size=512K]
07:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
        Subsystem: Super Micro Computer Inc Device 0000
        Region 0: Memory at dfa00000 (32-bit, non-prefetchable) [size=128K]
        Region 2: I/O ports at b000 [size=32]
        Region 3: Memory at dfa20000 (32-bit, non-prefetchable) [size=16K]
        Capabilities: [c8] Power Management version 2
                Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
        Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
        Capabilities: [e0] Express (v1) Endpoint, MSI 00
                DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
                DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
                        RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop+
                DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr+ TransPend-
                LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <128ns, L1 <64us
                LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
        Capabilities: [a0] MSI-X: Enable+ Count=5 Masked-
                Vector table: BAR=3 offset=00000000
                PBA: BAR=3 offset=00002000
                UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq+ ACSViol-
                CESta:  RxErr+ BadTLP+ BadDLLP+ Rollover- Timeout- NonFatalErr+
                AERCap: First Error Pointer: 14, GenCap- CGenEn- ChkCap- ChkEn-
        Capabilities: [140 v1] Device Serial Number 00-25-90-ff-ff-a4-e3-7a
        Kernel driver in use: e1000e
        Kernel modules: e1000e
08:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
        Interrupt: pin A routed to IRQ 18
        Region 0: Memory at df900000 (32-bit, non-prefetchable) [size=128K]
        Region 2: I/O ports at a000 [size=32]
        Region 3: Memory at df920000 (32-bit, non-prefetchable) [size=16K]
                AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
        Capabilities: [140 v1] Device Serial Number 00-25-90-ff-ff-a4-e3-7b
09:03.0 VGA compatible controller: Matrox Electronics Systems Ltd. MGA G200eW WPCM450 (rev 0a) (prog-if 00 [VGA controller])
        Latency: 64 (4000ns min, 8000ns max), Cache Line Size: 64 bytes
        Interrupt: pin A routed to IRQ 11
        Region 0: Memory at de000000 (32-bit, prefetchable) [size=16M]
        Region 1: Memory at df800000 (32-bit, non-prefetchable) [size=16K]
        Region 2: Memory at df000000 (32-bit, non-prefetchable) [size=8M]
        Expansion ROM at <unassigned> [disabled]
        Capabilities: [dc] Power Management version 1
                Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
