By default, most systems assume to handle this printer using "HPLIP", but then requires a proprietary driver. Therefore, I'm using "foo2zjs" as driver backend, which works perfectly and is Free Software
Make sure you have the following packages installed:
$ apt-get install cups foo2zjsCode: Select all
$ apt-get install cups printer-driver-foo2zjsIt already says "recommended"HP LaserJet Pro P1102w Foomatic/foo2zjs-z2 (recommended)
The following setups have worked flawlessly:
- Xubuntu 11.10 (Precise Pangolin)
- cups: 1.5.0-8ubuntu6
- foo2zjs: 20110811dfsg-1ubuntu1
- Raspbian 7 (Wheezy/Sid)
- cups: 1.5.3-5
- foo2zjs: 20120510dfsg0-1
