HP Laserjet P1102w & CUPS (GNU/Linux)
Posted: Sat Aug 17, 2013 3:57 pm
This thread contains information about using the printer "HP Laserjet P1102w" with GNU/Linux systems.
By default, most systems assume to handle this printer using "HPLIP", but then requires a proprietary driver. Therefore, I'm using "foo2zjs" as driver backend, which works perfectly and is Free Software
Make sure you have the following packages installed:
UPDATE: On newer Debian-based distros (e.g. raspbian-jessie), the package name for "foo2zjs" was changed to "printer-driver-foo2zjs". Therefore:
As printer model/driver choose:
The following setups have worked flawlessly:
$ apt-get install cups foo2zjs
$ apt-get install cups printer-driver-foo2zjs
It already says "recommended"HP LaserJet Pro P1102w Foomatic/foo2zjs-z2 (recommended)
- Xubuntu 11.10 (Precise Pangolin)
- cups: 1.5.0-8ubuntu6
- foo2zjs: 20110811dfsg-1ubuntu1
- Raspbian 7 (Wheezy/Sid)
- cups: 1.5.3-5
- foo2zjs: 20120510dfsg0-1
