RHEL6: Unable to access any Samba share
Posted: Mon Aug 19, 2013 4:18 pm
I was trying to configure a folder to be shared using Samba, on a Redhat Enterprise Linux Server (RHEL) 6.
I did the usual things, like adding my user using "smbpasswd", adding a share config block to /etc/samba/smb.conf - and restarted "smb" and "nmb" services.
I could open the RHEL6 server from Windows7, and logon worked as expected.
But as soon as I tried to open any share on that RHEL6 samba server, I got an error message telling me something like "access denied":
(Sorry, only have the errormessage in German at the moment)
Auf \\<servername>\<sharename> konnte nicht zugegriffen werden.
Sie haben keine Berechtigung für den Zugriff auf \\<servername>\<sharename>. Wenden Sie sich an den Netzwerkadministrator, um den Zugriff anzufordern.
I've checked everything. Several times.
SELinux must be told to allow access to the shared folder:
chcon -t samba_share_t <shared_foldername>
After telling SELinux that my shared folder was of type "Samba Share", I finally was able to access it.
Details for setting up Samba on RHEL6, can be found in Edward Hurst's blog entry title "RHEL 6 for the Clueless: Samba Server (Updated)".
RHEL6 + GlusterFS + SELinux + Samba = Operation not supporte
Posted: Mon Aug 19, 2013 4:20 pm
On the same Redhat Enterprise Linux Server, I made another uncomfortable discovery:
chcon: failed to change context of `/mnt/gluster_share' to `system_u:object_r:samba_share_t:s0': Operation not supported
First, take a look at SELinux settings regarding Samba:
$ getsebool -a | grep samba
On my setup this returns:
samba_create_home_dirs --> off
samba_domain_controller --> off
samba_enable_home_dirs --> off
samba_export_all_ro --> off
samba_export_all_rw --> off
samba_portmapper --> off
samba_run_unconfined --> off
samba_share_fusefs --> off
samba_share_nfs --> off
sanlock_use_samba --> off
use_samba_home_dirs --> off
virt_use_samba --> off
What caught my attention was:
GlusterFS is a fuse filesystem, so let's enable sharing fusefs over Samba:
$ setsebool samba_share_fusefs=on
Voila! :)
That did the trick: Now I was able to access the mounted Gluster folder over Samba.
References:
Redhat Bugzilla: Bug 910380 - unable to execute selinux "chcon" on gluster mounts
SELinux blocking Samba directory listing
RHEL6: Samba and iptables firewall
Posted: Tue Feb 18, 2014 7:22 pm
By default, the ports used by Samba are filtered by RHEL's iptables firewall.
In "/etc/sysconfig/iptables", add the following line, before the first "-j REJECT", so it looks like this:
-A INPUT -p tcp --dport 445 -j ACCEPT
-A INPUT -j REJECT --reject-with icmp-host-prohibited
The "--reject-with icmp-host-prohibited" line should already be in there, but it's important that the rule for destination port (--dport) 445 (=Microsoft-ds) is before it.
Then load the iptables, using "iptables-restore":
$ cat /etc/sysconfig/iptables | iptables-restore
If everything went fine, the output of "iptables -L" should look like this:
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
ACCEPT     all  --  anywhere             anywhere            state RELATED,ESTABLISHED
ACCEPT     icmp --  anywhere             anywhere
ACCEPT     tcp  --  anywhere             anywhere            state NEW tcp dpt:ssh
ACCEPT     tcp  --  anywhere             anywhere            tcp dpt:Microsoft-ds
REJECT     all  --  anywhere             anywhere            reject-with icmp-host-prohibited
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Thanks to Aaron Walrath's blog entry about Samba on Red Hat Enterprise Linux.
