VirtualDub + GlusterFS = Unable to open file
Trying to open AVI files with VirtualDub over Samba over GlusterFS mountpoint returns the following error message:
"Cannot read from file "xxx.avi": The process cannot access the file because another process has locked a portion of the file."
Other applications can open the file (e.g. VLC), but it seems that VirtualDub's locking behavior doesn't play well with a default GlusterFS setup.
Opening the same file directly from the GlusterFS "bricks" mountpoints over Samba, works fine.
GlusterFS shared over Samba obviously has similar properties like sharing NFS.
The solution is to disable strict locking in Samba's global section in "/etc/samba/smb.conf"
[global]
strict locking = no
Thanks to the thread [Samba] The process cannot access the file because another process has locked a portion of the file on "fixunix.com".
References:
