VirtualDub + GlusterFS = Unable to open file
Posted: Tue Aug 20, 2013 5:13 pm
Trying to open AVI files with VirtualDub over Samba over GlusterFS mountpoint returns the following error message:
Opening the same file directly from the GlusterFS "bricks" mountpoints over Samba, works fine.
GlusterFS shared over Samba obviously has similar properties like sharing NFS.
The solution is to disable strict locking in Samba's global section in "/etc/samba/smb.conf"
Thanks to the thread [Samba] The process cannot access the file because another process has locked a portion of the file on "fixunix.com".
References:
Other applications can open the file (e.g. VLC), but it seems that VirtualDub's locking behavior doesn't play well with a default GlusterFS setup."Cannot read from file "xxx.avi": The process cannot access the file because another process has locked a portion of the file."
[global]
strict locking = no
References:
