vsftpd + Ubuntu: Fix "500 OOPS" writeable chroot
Posted: Mon Dec 09, 2013 11:55 pm
More recent versions of vsftpd have enabled a new security feature by default:
A user may not login to a chroot'ed environment, if the (ch)root folder is writable.
It's explained in vsftpd's FAQs:
However.
In order to restore a setup to the same security and functionality state as with previous versions, you can override this by adding the following rule to your /etc/vsftpd.conf:
Unfortunately, this feature is added in vsftpd v3.x, so when running the recent Debian Stable (v7 Squeeze) or Ubuntu LTS (12.04 "precise pangolin"), you will get the following error:
1) Install "The Frontier Group"'s PPA:
2) Update apt-cache:
3) Install the PPA version of vsftpd:
4) Add the config line to /etc/vsftpd.conf to allow writeable chroot:
5) Restart vsftpd:
Voila. That's it.
I must admit, that I have to read up a bit more, why it's not good to have the user own the chroot'ed folder. Especially if the most typical use case for this is to limit users to their home directories (which are, of course, owned by them).vsftpd is protecting against dangerous configurations.
The cause of this message is usually dodgy ownership of the ftp home directory. The home directory should NOT be owned by the ftp user itself. Neither should it be writable by the ftp user.
However.
allow_writeable_chroot=YES
For Ubuntu you can do the following:500 OOPS: unrecognised variable in config file: allow_writeable_chroot
- Add "The Frontier Group"'s PPA
- Update the vsftpd package (to the PPA version)
$ sudo add-apt-repository ppa:thefrontiergroup/vsftpd
$ sudo apt-get update
$ sudo apt-get install vsftpd
$ sudo service vsftpd restart
