Inkscape: "UniConvertor failed" when trying to copy/paste
Posted: Sun Jan 26, 2014 1:35 am
Me, a happy Inkscape user, suddenly ran into a minor, but rather annoying problem. The system was Xubuntu Precise Pangolin (12.04.1 LTS, 64bit) and Inkscape version "0.48.3.1 r9886" from the default repositories.
The issue was as follows:
Every time I copied some object into the clipboard (hitting "Ctrl+C"), an error message popped up. At the top it said:
And after a few seconds more windows pop up, with the same text at the top, but this time it just says:
to be continued...
followed by the actual error message:Inkscape has received additional data from the script executed. The script did not return an error, but this may indicate the results will not be as expected.
UniConvertor failed:
Cannot list directory /home/pb/.uniconvertor:[Errno 2] No such file or directory: '/home/pb/.uniconvertor'
ignoring it in font_path
I can't find font Sans. I'll use Slim instead
Fontsystem not yet implemented in UniConvertor. See /usr/share/doc/python-uniconvertor/README.Debian for more info
Traceback (most recent call last):
File "<string>", line 1, in <module>
File "/usr/lib/python2.7/dist-packages/uniconvertor/__init__.py", line 88, in uniconv
saver(doc, output_file)
File "/usr/lib/python2.7/dist-packages/uniconvertor/app/plugins/plugins.py", line 201, in __call__
module.save(document, file, filename, options)
File "/usr/lib/python2.7/dist-packages/uniconvertor/app/plugins/Filters/wmfsaver.py", line 461, in save
saver.SaveDocument(document)
File "/usr/lib/python2.7/dist-packages/uniconvertor/app/plugins/Filters/wmfsaver.py", line 403, in SaveDocument
left, bottom, right, top = doc.BoundingRect()
File "/usr/lib/python2.7/dist-packages/uniconvertor/app/Graphics/document.py", line 221, in BoundingRect
rect = layer.bounding_rect
File "/usr/lib/python2.7/dist-packages/uniconvertor/app/Graphics/base.py", line 352, in __getattr__
getattr(self, method)()
File "/usr/lib/python2.7/dist-packages/uniconvertor/app/Graphics/compound.py", line 174, in update_rects
boxes = map(lambda o: o.coord_rect, self.objects)
File "/usr/lib/python2.7/dist-packages/uniconvertor/app/Graphics/compound.py", line 174, in <lambda>
File "/usr/lib/python2.7/dist-packages/uniconvertor/app/Graphics/text.py", line 492, in update_rects
rect = apply(Rect, a.font.TextBoundingBox(self.text, a.font_size, a))
TypeError: TextBoundingBox() takes exactly 3 arguments (4 given)
No layers found
