"ERROR: This RRD was created on another architecture"
Posted: Wed Mar 12, 2014 1:17 pm
Today I wanted to manually create graphs from RRDTool ".rrd" files, created with Cacti. I copied the files over to another computer, but when I tried to run a "rrdtool graph ..." on them, I got the following error:
Thanks to the blog article "Converting 32bit RRD to 64bit RRD (moving cacti between architectures)" by Carl Heaton, the solution is easy:
Convert the RRD files to XML, copy the XMLs (instead of the RRDs) to another host, and then convert them back to RRDs.
I took Carl's instructions and created a small BASH script:
Now just run the script with argument "export" on the RRDs, and then with "import" on the XMLs.
That was true: The cacti host was 32bits and the host I wanted to draw the graphs on was 64bits.ERROR: This RRD was created on another architecture
#!/bin/bash
case "$1" in
export)
for FILE in `ls *.rrd`; do
echo -n "Converting '$FILE' to XML... "
rrdtool dump $FILE > $FILE.xml
echo "OK"
done
import)
for FILE in `ls *.xml`; do
echo -n "Converting '$FILE' to RRD... "
FILE_OUT=$(basename "$FILE")
rrdtool restore $i $FILE_OUT
echo "OK"
done
echo ""
echo "SYNTAX: $0 (import|export)"
echo ""
esac
