If you try to use the mysql_ plugin(s) with munin, you receive errors about "Cache::Cache" missing.
E.g. "Missing dependency Cache::Cache at ./mysql_"
For some reason, a package that the mysql_ plugin is depending on is not installed as a munin prerequisite. Install the package:
apt-get install libcache-cache-perl
munin-node-configure --suggest
mysql_ | yes | yes (commands connections files_tables innodb_bpool innodb_bpool_act innodb_insert_buf innodb_io innodb_io_pend innodb_log innodb_rows innodb_semaphores innodb_tnx myisam_indexes network_traffic qcache qcache_mem select_types slow sorts table_locks tmp_tables +bin_relay_log +replication)
