Gluster:{path} or a prefix of it is already part of a volume
Posted: Wed Mar 26, 2014 12:51 pm
I've set up a new glusterfs node and wanted to re-use disks which previously already contained a glusterfs volume.
When trying to create the gluster volume on the new setup, I was (of course) confronted with the following error message:
Now, the "volume create" command should complete successfully
According to Joe Julian's blog, an existing gluster volume data folder can be "freed" to be reused, by removing some file attributes and the .glusterfs folder:volume create: dlp-storage: failed: /exports/brick1/data or a prefix of it is already part of a volume
setfattr -x trusted.glusterfs.volume-id $brick_path
setfattr -x trusted.gfid $brick_path
rm -rf $brick_path/.glusterfs
