Munin on Raspberry Pi: some graphs not working
Posted: Wed Mar 26, 2014 11:20 pm
I'm just trying to setup monitoring using "Munin" on a Raspberry Pi.
The installation was super easy, and graphs are updated every 5 minutes out of the box.
Unfortunately, some graphs were only generated when munin-node was started, but don't get updated.
In my case, the plugins which seem to have problems are:
Following the "Plugin Debugging" article in the Munin docs, I tried executing the "diskstats" plugin manually (as root):
I get the following error:
It's telling the truth: "/var/lib/munin-node" exists, but is completely empty and belongs to "root:root" (see Debian Bug #679897).
[MID-SOLUTION]
I've changed ownership to "munin:munin" and created the "plugin-state" subfolder:
Now, "munin-run diskstats" runs without error and also created the file: /var/lib/munin-node/plugin-state/nobody/diskstats-
Still, no graphs for diskstats
So I tried connecting to munin-node directly and fetch diskstats:
Returns:
Now I get:
Okay. I've now copied the "diskstats-" file in "/var/lib/munin-node/plugin-state/nobody" to both IPs of my server:
Now, running the "fetch diskstats" per "nc" again, returns values! YAY!
The timestamp in the diskstats graphs is now updated like the others
Victory is mine!
It currently works, but I'm not 100% sure which of the "nobody/diskstats-*" files are now actually used/valid. Furthermore, I'd like to figure out the correct chown/chmod settings for it.
- diskstats
- munin_stats
$ sudo munin-run diskstats
It's weird that it mentions user "nobody" and no IP at the end of "diskstats-", but:diskstats: Could not open statefile '/var/lib/munin-node/plugin-state/nobody/diskstats-' for writing: No such file or directory
[MID-SOLUTION]
$ sudo mkdir -p /var/lib/munin-node/plugin-state
$ sudo chown -R munin:munin /var/lib/munin-node
$ echo fetch diskstats | nc localhost 4949
So I checked the "/var/log/munin-node.log" (again).Bad exit
Now I get:
[SOLUTION]2014/03/26-22:52:28 [31601] Error output from diskstats:
2014/03/26-22:52:28 [31601] diskstats: Could not open statefile '/var/lib/munin-node/plugin-state/nobody/diskstats-127.0.0.1' for writing: Permission denied
2014/03/26-22:52:28 [31601] Service 'diskstats' exited with status 13/0.
- /var/lib/munin-node/plugin-state/nobody/diskstats-127.0.0.1
- /var/lib/munin-node/plugin-state/nobody/diskstats-192.168.1.x
Victory is mine!
