Gluster: accidential peer "takeover" by "peer probe"
Imagine the following Gluster setup:
  • 2 Servers (aka "node" or "peer").
  • Let's call them "A" and "B".
  • A and B are setup independently, but completely identical (=same "volume name").
  • A is the production pool, B is the asynchronously sync'd backup.
  • A contains 71 TB on 3 bricks. B is not fully sync'd and only contains around 65 TB.
Everything was running perfectly, until I tried to prepare for adding new bricks on a new node to "A":
I thought "peer probe" was just "probing" (=checking status, availability, etc) a node, so I tried to probe A on A:
peer probe: success: on localhost not needed
Okay, so I tried to probe A from B.
Big mistake...
This caused B to overwrite A's (production-use!) configuration. "/var/lib/glusterd" was now pointing to bricks on B.
Since B was a copy of A, it wasn't obvious what happened, since user access over Samba to A's mountpoint, silently retrieved the data from B's bricks.
Actually, this is great! It shows how nice Gluster does it's job. Seriously: This is exactly what we wanted to have Gluster for - but my "peer probe" caused an uncomfortable situation:
The test-volume "B" now acted as production pool, but being referenced through Samba on "A". Ouch! :shock:
The fact that A and B had identical volume names, led to the problem that A's brick-configuration was overwritten by B's config.
Luckily, it was rather straightforward:
1) Detach the wrongly connected peer:
On server B, detach A:
$ gluster peer detach A
You can't do it the other way around, or A will complain that bricks on B are still in use.
B never needed A in this constellation anyway, so B continues to run fine. Standalone.
2) Create the volume again on A:
A and B had identical volume names, so detaching A removed any reference to its previous volume configuration.
Therefore, create a new one. Same name as before. In our case "dlp-storage":
$ gluster volume create dlp-storage
Now, we need to re-assign this volume's previously owned bricks.
3) "Free" the bricks on A:
In order to re-add the bricks on A to A, we must clear some extended file attributes (xattrs) first.
See "{path} or a prefix of it is already part of a volume" for instructions how to do so.
In my case, I've used "mv" rather than "rm" for the ".gluster" folder - to be able to roll-back the previous config. Just in case...
Here's it in a nutshell:
Make a backup of the xattrs you're about to clear:
$ getfattr --absolute-names -d -m - /path/of/brick{1,2,3}/data >> backup_xattr.txt
Now, clear the attributes and move the ".glusterfs" folder out of the way (but keep it for recovery reasons):
$ setfattr -x trusted.glusterfs.volume-id $brick_path
$ setfattr -x trusted.gfid $brick_path
$ mv -rf $brick_path/.glusterfs $brick_path/.glusterfs-DELME
NOTE: You must run this on each brick's data path.
4) Add the bricks to the volume on A:
$ gluster volume add-brick dlp-storage hostname_a:/path/of/brick1/data hostname_a:/path/of/brick2/data hostname_a:/path/of/brick3/data
Guess what? That's actually almost it!
5) Start the volume and mount it:
$ gluster volume start dlp-storage
Then, mount it under a new mountpoint. In our case we had "/mnt/dlp-storage" as regular one (=now temporarily mounted "B"), and "/mnt/dlp-test" for this recovered "A".
"df -h" showed that the previous data on the bricks was instantly found and available in the gluster volume: 71 TB all happily there! :D
There wasn't even any noticeable waiting time. The ".glusterfs" folders on each brick were also immediately rebuilt.
Finally, I've rsync'd the delta that B aquired during this "misconfiguration phase" back to A:
$ rsync -avP /mnt/dlp-storage/ /mnt/dlp-test/
Debriefing:
I would have expected a warning when doing "gluster peer probe" on a node that already has a volume with an identical name - preventing this from happening in the first place (Reminder to myself: Add it to their bugtracker). But nevertheless, this showed how the folder/file-based design allows to quickly switch between nodes/bricks - and re-integrate existing data.
