Bluetooth
Posted: Tue Jul 26, 2005 3:52 pm
This thread will contain several 'funny' things we've encountered playing around with Bluetooth devices.
Here's my first one for today:
Bluetooth support on an IBM Thinkpad R51:
With WinXP SP1 things don't even seem to work at all with the driver that windows "thinks" is best - There is an unsigned driver from IBM which works perfectly (driver's date is January 2004).
BUT:
This notebook had to be reinstalled - this time it was SP2. I knew that the driver mentioned above worked properly and it also installed the "my bluetooth places" and everything, so I wanted to uninstall the 'new' SP2-driver (Date: March 2004) and use the older one (Jan04).
Well... not with windows...
Although I was able to uninstall the new, signed driver I ended up with a mixture of old and new stuff hopelessly colliding with each other. When trying to enable bluetooth it even told me that I wasn't allowed to install an older BT-software version if a newer one was already installed. GREAT!
Although I haven't figured out how to get the "my bluetooth places" without installing the vendor's (IBM) software, but in my case things only work when using the SP2 (Mar04) driver.
BUT:
