XFS: "Internal error XFS_WANT_CORRUPTED_GOTO"
Posted: Thu Mar 19, 2015 2:09 pm
Our GlusterFS share was filled up almost completely, when I suddenly got I/O errors on directory listings, not showing some of the folders on the bricks.
Checking /var/log/messages, gave hints that XFS seems to have troubles:
This only happened on the one of 3 identical Software-RAIDs that is completely full (64kB free). Coincidence or is XFS having problems when running out of space?
Those are storage-partitions, so I did not reserve any additional space for "root" (as is good practice for system disks) to avoid such issues.
I'm not too happy with this.
1) Umounted the gluster share, then stop the gluster volume:
2) Unmount affected XFS brick and run "xfs_repair":
First, I ran xfs_repair in non-modify mode, so I could see what it would do:
It listed some inodes/files that came in when the disk was running out of space. Some of the files were clearly visible as rsync-temp files.
After checking the output of the dry-run, I got the following message when running xfs_repair without "-n":
3) Mount fixed XFS brick and restart/remount Gluster volume.
That's it. Seems to have worked
How to prevent this in the future?
It seems that "cluster.min-free-disk" only imposes a soft-limit that issues a warning in the logs, rather than preventing data to be written onto the bricks.
XFS doesn't support the "reserved for superuser" flag (like EXT3/4), so a viable option might be to implement user-based "quota" rules?
Mar 19 04:39:15 vm-gluster-1 kernel: XFS: Internal error XFS_WANT_CORRUPTED_GOTO at line 1327 of file fs/xfs/xfs_alloc.c. Caller 0xffffffffa014404d
Mar 19 04:39:15 vm-gluster-1 kernel: Pid: 615, comm: xfsalloc/1 Not tainted 2.6.32-431.5.1.el6.x86_64 #1
Mar 19 04:39:15 vm-gluster-1 kernel: Call Trace:
Mar 19 04:39:15 vm-gluster-1 kernel: [<ffffffffa016ce5f>] ? xfs_error_report+0x3f/0x50 [xfs]
Mar 19 04:39:15 vm-gluster-1 kernel: [<ffffffffa014404d>] ? xfs_alloc_ag_vextent+0xad/0x100 [xfs]
Mar 19 04:39:15 vm-gluster-1 kernel: [<ffffffffa0141679>] ? xfs_alloc_lookup_eq+0x19/0x20 [xfs]
Mar 19 04:39:15 vm-gluster-1 kernel: [<ffffffffa01431df>] ? xfs_alloc_ag_vextent_size+0x38f/0x630 [xfs]
Mar 19 04:39:15 vm-gluster-1 kernel: [<ffffffffa0144a9c>] ? xfs_alloc_vextent+0x2bc/0x610 [xfs]
Mar 19 04:39:15 vm-gluster-1 kernel: [<ffffffffa014f2c8>] ? xfs_bmap_btalloc+0x398/0x700 [xfs]
Mar 19 04:39:15 vm-gluster-1 kernel: [<ffffffffa014f63e>] ? xfs_bmap_alloc+0xe/0x10 [xfs]
Mar 19 04:39:15 vm-gluster-1 kernel: [<ffffffffa0155622>] ? __xfs_bmapi_allocate+0x102/0x340 [xfs]
Mar 19 04:39:15 vm-gluster-1 kernel: [<ffffffff81527c20>] ? thread_return+0x4e/0x76e
Mar 19 04:39:15 vm-gluster-1 kernel: [<ffffffffa01559a0>] ? xfs_bmapi_allocate_worker+0x70/0xa0 [xfs]
Mar 19 04:39:15 vm-gluster-1 kernel: [<ffffffffa0155930>] ? xfs_bmapi_allocate_worker+0x0/0xa0 [xfs]
Mar 19 04:39:15 vm-gluster-1 kernel: [<ffffffff81094d10>] ? worker_thread+0x170/0x2a0
Mar 19 04:39:15 vm-gluster-1 kernel: [<ffffffff8109b290>] ? autoremove_wake_function+0x0/0x40
Mar 19 04:39:15 vm-gluster-1 kernel: [<ffffffff81094ba0>] ? worker_thread+0x0/0x2a0
Mar 19 04:39:15 vm-gluster-1 kernel: [<ffffffff8109aee6>] ? kthread+0x96/0xa0
Mar 19 04:39:15 vm-gluster-1 kernel: [<ffffffff8100c20a>] ? child_rip+0xa/0x20
Mar 19 04:39:15 vm-gluster-1 kernel: [<ffffffff8109ae50>] ? kthread+0x0/0xa0
Mar 19 04:39:15 vm-gluster-1 kernel: [<ffffffff8100c200>] ? child_rip+0x0/0x20
Mar 19 04:39:15 vm-gluster-1 kernel: XFS (vdd): Internal error xfs_trans_cancel at line 1948 of file fs/xfs/xfs_trans.c. Caller 0xffffffffa0178c5d
$ umount $YOUR_GLUSTER_MOUNTPOINT
$ gluster volume stop $VOLUME_NAME
$ xfs_repair -n /dev/sdX
I mounted the XFS brick, and unmounted it, as described in the message and then re-ran the same xfs_repair call:Phase 1 - find and verify superblock...
Phase 2 - using internal log
- zero log...
ERROR: The filesystem has valuable metadata changes in a log which needs to
be replayed. Mount the filesystem to replay the log, and unmount it before
re-running xfs_repair. If you are unable to mount the filesystem, then use
the -L option to destroy the log and attempt a repair.
Note that destroying the log may cause corruption -- please attempt a mount
of the filesystem before doing this.
$ xfs_repair /dev/sdX
