When trying to compile net-tools 1.60 with GCC 3.4.1, you probably get:
inet_sr.c:108: error: label at end of compound statement
Make a copy of the file and edit /lib/inet_sr.c and add a "break;" between "default:" and the closing "}", because the new gcc doesn´t like to have nothing there.
Net-tools 1.60 compile error
More Information
You can fix several problems when compiling this package the way described above, just in different sourcefiles. Just check the line number in the error message.
