Kernel 2.6.x "assumes" old config
Posted: Wed Aug 17, 2005 5:29 pm
I had a problem with a kernel I´ve compiled, so I wanted to make a new one - starting completely from scratch in order to avoid problems introduced in my last build. So I ran "make mrproper" on a freshly unzipped kernel source.
But what happened???
When I ran "make menuconfig", it had my old settings already applied automatically. :shock: WTF???
Why is it doing this? And which config did it use? And there is NO note about this behavior in the README. *sigh*
I found out that it looks for config* files within the /boot directory and I think it takes the one with the youngest date.
Remove or rename all config* files there and the new kernel should not find anything anymore.
[REMARKS] :evil:
What the hell has happened to the kernel developers? This behavior is windows-style: "I´m guessing, because you are an idiot-user...". I am soooo angry! I mean: I was able to workaround this stupid idea, but who came up with it anyway?
There IS a make parameter called "oldconfig" - and if I wanted to keep anything from my old config I could do it - I do not need idiot-supporting-and-making-things-worse mechanisms!
