APC USV: Error connecting to network module
Posted: Tue Sep 22, 2015 8:21 pm
Trying to connect to the APC UPS network module per web-interface (http).
Got the following error:
No error visible, except that the eventlog seems to behave weird:
I've compared the details to an identical UPS. All firmware versions match:
I've tried the following:
http://blog.mpecsinc.ca/2012/06/apc-ap9 ... error.html
http://www.apcmedia.com/salestools/MLAN ... _R0_EN.pdf
http://technologyordie.com/apc-network- ... -cli-setup
Logging in per Telnet (Thanks PuTTY!) to the UPS.Error: The application was not able to load.
You are attempting to access a Schneider device.
There was a problem loading the application. Please login to the device via telnet for more details.
apc>eventlog
E100: Command Failed
Event Log Not Available
apc>system
E000: Success
Contact: Unknown
DateTime: 05/29/2014:02:53:26
User: Administrator
Up Time: 65 Days 21 Hours 29 Minutes
Stat: P+ N4+ N6+ A-
Bootmon: bootmon:v1.0.2
AOS: aos:v5.1.7
App: sumx:v5.1.7
- reboot
- resetToDef & reboot
- format & reboot
