Korg Triton Le: How to record Arpeggios as MIDI
Posted: Sun Aug 28, 2005 7:16 pm
I wanted to record a Korg Triton Le, but the audio output AND the MIDI signals, too.
Simply recording what's coming from the Korg's MIDI output didn't do the trick, because most of the song was actually generated using Korg's Arpeggios - AND they're sent to the Internal sequencer, thus not showing up on the recording device.
Change the Arpeggios options to use to the external (EXT) MIDI output (instead of the Internal one (INT)).
In the menu: "Combi 3.1" you have a list of the Timbres assigned to each Arpeggiator (A or B) and they're defaulting to "INT and GCh" which means (Internal and Global Channel) - Change the "INT" to "EXT".
[DRAWBACK]
Each Timbre sent to EXT is not handled by the internal sequencer anymore which means that you will NOT receive the Korg's audio signal for it.
[DRAWBACK]
