odpdown & Xubuntu: No module named setuptools
Posted: Sat Jan 16, 2016 3:09 am
Trying to run Thorsten Behrens' markdown-to-odp converter "odpdown" on Xubuntu 12.04 Precise (LTS).
Following odpdown's installtion instructions, I downloaded it an ran:
Worked.
Now it returns:
$ python setup.py install
Threw the following error:
Traceback (most recent call last):
File "setup.py", line 4, in <module>
from setuptools import setup
ImportError: No module named setuptools
$ sudo apt-get install python-setuptools
Now it returns:
running install
running build
running build_py
running build_scripts
running install_lib
copying build/lib.linux-x86_64-2.7/odpdown.py -> /usr/local/lib/python2.7/dist-packages
byte-compiling /usr/local/lib/python2.7/dist-packages/odpdown.py to odpdown.pyc
running install_egg_info
running egg_info
creating odpdown.egg-info
writing requirements to odpdown.egg-info/requires.txt
writing odpdown.egg-info/PKG-INFO
writing top-level names to odpdown.egg-info/top_level.txt
writing dependency_links to odpdown.egg-info/dependency_links.txt
writing manifest file 'odpdown.egg-info/SOURCES.txt'
reading manifest file 'odpdown.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no files found matching 'appveyor.yml'
warning: no previously-included files matching '*.py[co]' found anywhere in distribution
warning: no previously-included files matching '__pycache__' found anywhere in distribution
warning: no previously-included files matching '*.so' found anywhere in distribution
warning: no previously-included files matching '*.pyd' found anywhere in distribution
Copying odpdown.egg-info to /usr/local/lib/python2.7/dist-packages/odpdown-0.4.1.egg-info
running install_scripts
copying build/scripts-2.7/odpdown -> /usr/local/bin
