Debian 8.4 Installer: Can't destroy MDRaid because in use
Posted: Fri Sep 30, 2016 8:14 pm
by gilthanaz
I just tried to install Debian on Disks that had been a raid array earlier. The installer recognizes this but delete fails because one of the old arrays was somehow active.
The issue was that a swap partition was a raid1 and the installer did recognize it as such, and use it. To be able to destroy the raids and completely wipe the partition tables in the installer, I had to go to a Shell (Ctrl+Alt+F2) and execute some commands.
!!!!! VERY DESTRUCTIVE - BE CAREFUL !!!!!
# swapoff /dev/mdx
# mdadm --stop /dev/mdx
(where x = the MD device that couldn't be deleted)
You can switch back to the installer with Ctrl+Alt+F1 and then use the GUI to delete the stopped md raid and consequently the used partitions of the mdadm softraid.
