I wasn't able to figure out who generates the files in
/etc/avahi/services, or where they are installed from. They just seem to "appear" - but there's no information found on the Internet that would explain which process created them.
Mysterical...
Anyways, I was able to recover existing .service files from an older installation of raspbian (wheezy).
I simply copied them over to the "
/etc/avahi/services" folder and restarted the avahi-daemon:
Below are some example .service files from my setup:
cups.service:
<?xml version="1.0" standalone='no'?><!--*-nxml-*-->
<!DOCTYPE service-group SYSTEM "avahi-service.dtd">
<service-group>
<name replace-wildcards="yes">Printer configuration on %h</name>
<service>
<type>_http._tcp</type>
<port>631</port>
<txt-record>path=/printers/HP_LaserJet_P1102w</txt-record>
</service>
</service-group>
http.service
<service-group>
<name replace-wildcards="yes">Webserver on %h</name>
<service>
<port>80</port>
<txt-record>path=/media_catalog/</txt-record>
</service>
</service-group>
smb.service
<service-group>
<name replace-wildcards="yes">Fileserver on %h</name>
<service>
<type>_smb._tcp</type>
<port>445</port>
<txt-record>path=browse</txt-record>
</service>
</service-group>
ssh.service
This file is part of avahi.
avahi is free software; you can redistribute it and/or modify it
under the terms of the GNU Lesser General Public License as
published by the Free Software Foundation; either version 2 of the
License, or (at your option) any later version.
avahi is distributed in the hope that it will be useful, but
WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with avahi; if not, write to the Free Software
Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA
02111-1307 USA.
<!-- See avahi.service(5) for more information about this configuration file -->
<service-group>
<name replace-wildcards="yes">%h</name>
<service>
<type>_ssh._tcp</type>
<port>22</port>
</service>
</service-group>
