Raspberry Pi: Installing images on Linux
Most of the documentation found for installing some distributions on SD card for Raspberry Pi are tailored for Windows or Mac users.
This is pretty useless for someone using GNU/Linux, so I'm collecting some information here for how to write these image files (.img.gz) to an SD-card using non-fancy, plain-vanilla tools available under most distros.
Links: Works-on-my-machine BASH script, so I don't need to remember how to dd the images on the SD cards:
#!/bin/bash
# Installation HowTo:
#   http://wiki.openelec.tv/index.php/HOW-TO:Installing_OpenELEC/Writing_The_Disk_Image
function install_image
    local IMAGE_MASK="$1"
    local DEVICE="$2"
    if [ -z "$DEVICE" ]; then
        echo "ERROR: No device name given."
        exit 1
    else
        DEVICE="/dev/$DEVICE"
        if [ -b "$DEVICE" ]; then
            echo "Device '$DEVICE' is a block device. Good."
        else
            echo "ERROR: Device '$DEVICE' is NOT a block device."
            exit 2
        fi
    fi
    for IMAGE_GZ in `ls $IMAGE_MASK`; do
        echo "Image file: '$IMAGE_GZ'"
        IMAGE_FILE="$(basename $IMAGE_GZ '.gz')"
        IMAGE_DIR="$(dirname $IMAGE_GZ)"
        IMAGE="$IMAGE_DIR/$IMAGE_FILE"
        if [ ! -s "$IMAGE" ]; then
            echo "Need to unpack '$IMAGE_GZ'..."
            CMD="gunzip -c -d $IMAGE_GZ > $IMAGE"
            echo "$CMD"
            eval "$CMD"
        else
            echo "Unpacked file '$IMAGE' already exists."
        fi
        echo ""
        read -p "Press any key to start writing on '$DEVICE'..."
        echo ""
        echo "Copying image to device '$DEVICE'..."
        CMD="sudo dd if=$IMAGE of=$DEVICE bs=4M"
        echo "$CMD"
        eval "$CMD"
        # We only do the most recent file. Therefore exit for-loop now:
        break;
    done
function write_header
    DISTRO="$1"
    DEVICE="$2"
    VERSION="$3"
    IMAGE_MASK="$4"
    echo "============================="
    echo "$DISTRO (v$VERSION)"
    echo ""
    echo "Writing on device '$DEVICE'."
    echo "Using filemask '$IMAGE_MASK'."
    echo ""
    read -p "Press any key to continue..."
ACTION="$1"
DEVICE="$2"
VERSION="$3"
case "$ACTION" in
    retropie)
        IMAGE_MASK="RetroPie/retropie-$VERSION-*.img.gz"
        write_header "RetroPie" "$DEVICE" "$VERSION" "$IMAGE_MASK"
        install_image "$IMAGE_MASK" "$DEVICE"
    libreelec)
        # Default SSH login:
        #   root / libreelec
        IMAGE_MASK="LibreELEC/LibreELEC-RPi.arm-$VERSION.img.gz"
    openelec)
        #   root / openelec
        IMAGE_MASK="OpenELEC/OpenELEC-RPi.arm-$VERSION.img.gz"
    raspbian)
        #   pi / raspberry (watchout! US keyboard)
        IMAGE_MASK="Raspbian/*-raspbian-$VERSION-lite.img.gz"
        write_header "Raspbian" "$DEVICE" "$VERSION" "$IMAGE_MASK"
        echo ""
        echo "SYNTAX: $0 (retro|openelec|libreelec|raspbian) devicename version"
        echo ""
        echo "The 'devicename' must be without '/dev/'."
        echo ""
        echo ""
esac
