Xubuntu 16.04 & Virtualbox: "Failed to start LSB"
Posted: Sat Oct 14, 2017 11:07 pm
Fresh install of Xubuntu 16.04.3 (64bit).
When installing the "virtualbox" package, I got the following error:
Job for virtualbox.service failed because the control process exited with error code. See "systemctl status virtualbox.service" and "journalctl -xe" for details.
invoke-rc.d: initscript virtualbox, action "restart" failed.
● virtualbox.service - LSB: VirtualBox Linux kernel module
Loaded: loaded (/etc/init.d/virtualbox; bad; vendor preset: enabled)
Active: failed (Result: exit-code) since Sam 2017-10-14 19:37:30 CEST; 4ms ago
Docs: man:systemd-sysv-generator(8)
Process: 18867 ExecStart=/etc/init.d/virtualbox start (code=exited, status=1/FAILURE)
Okt 14 19:37:30 pb-combat systemd[1]: Starting LSB: VirtualBox Linux kernel module...
Okt 14 19:37:30 pb-combat virtualbox[18867]: * Starting VirtualBox kernel modules
Okt 14 19:37:30 pb-combat virtualbox[18867]: * No suitable module for running kernel found
Okt 14 19:37:30 pb-combat virtualbox[18867]: ...fail!
Okt 14 19:37:30 pb-combat systemd[1]: virtualbox.service: Control process exited, code=exited status=1
Okt 14 19:37:30 pb-combat systemd[1]: Failed to start LSB: VirtualBox Linux kernel module.
Okt 14 19:37:30 pb-combat systemd[1]: virtualbox.service: Unit entered failed state.
Okt 14 19:37:30 pb-combat systemd[1]: virtualbox.service: Failed with result 'exit-code'.
Trying to install the package again, just says everything's fine.
Hm...
