Blackmagic Decklink SDI: Non-persistent settings issue
Posted: Thu Nov 02, 2017 4:53 pm
I'm using a Blackmagic "Decklink SDI 4k" capture card on Windows 7.
Whenever I restart the PC or logout/login again, the capture card forgot its settings
Very annoying...
Seems to be related to a problem Blackmagic's firmware-update tool (CheckVersionPCI.exe):
For some unknown reason the version I have stays active as process in the background (listed in TaskManager).
But according to Joshua (from Blackmagic), "CheckVersionPCI.exe should run and terminate".
Current workaround is to disable the firmware-updater on startup.
Now, the card behaves as expected.
Very annoying...
- Run "msconfig"
- Select tab "Startup"
- "CheckVersionPCI.exe" had 2 entries on my system:
- Blackmagic CheckVersion
- Blackmagic Software Updater
- Disable them both.
- Apply changes (Click OK or Apply).
