Inkscape copy/paste issue
Posted: Thu Oct 18, 2018 5:34 pm
On Xubuntu 16.04 and Inkscape v0.91/r13725, hitting "Ctrl+C" in Inkscape returns the following error:
Hm. Reading this here doesn't look to good:
https://askubuntu.com/questions/940187/ ... lem#940209
An additional dialogue pops up right after:UniConvertor failed:
Traceback (most recent call last):
File "/usr/bin/uniconvertor", line 13, in <module>
uniconv_run()
File "/usr/lib/python2.7/dist-packages/uniconvertor/__init__.py", line 83, in uniconv_run
from app.io import load
File "/usr/lib/python2.7/dist-packages/uniconvertor/app/__init__.py", line 69, in <module>
from conf.configurator import Configurator
File "/usr/lib/python2.7/dist-packages/uniconvertor/app/conf/configurator.py", line 11, in <module>
from app.events import connector
File "/usr/lib/python2.7/dist-packages/uniconvertor/app/conf/configurator.py", line 13, in <module>
from sk1libs.utils.fs import gethome
ImportError: No module named sk1libs.utils.fs
This extension requires at least one non empty layer.
