https failing: SSL_ERROR_RX_RECORD_TOO_LONG
Posted: Wed Feb 06, 2019 2:41 pm
If you get the following error message when trying to connect to a site over HTTPS:
Check if you're actually connecting to HTTP, but prefixed the URL with "https://".
Common example is, if you're port-forwarding or SSH-tunneling http+https connections to non-default ports, and accidentally mixed them up in the URL.
That's what happened to me 2 minutes ago.
A bit embarrassing, but happens
[SOLUTION]Secure Connection Failed
An error occurred during a connection to sandbox.av-rd.com:10080. SSL received a record that exceeded the maximum permissible length. Error code: SSL_ERROR_RX_RECORD_TOO_LONG
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
