Oracle: Running under SuSE 10
Posted: Sun Dec 04, 2005 12:38 am
While trying to install Oracle 10g, I received the following message:
Checking operating system version: must be redhat-3, SuSE-9, redhat-4, UnitedLinux-1.0, asianux-1 or asianux-2
Failed <<<<
run the installer with this parameter:
[My-2-cents]
Every time I have to touch oracle, it gives me another reason why I do NOT like it.
Where is "rcoracle" (/etc/init.d/oracle)?
Posted: Sun Dec 04, 2005 12:43 am
Oracle's installation does NOT seem to come with proper startup scripts useful in the SysV init process.
Check the
SuSE ftp for RPMs including startup files for oracle.
I didn't want to blindly execute this RPM, so I unpacked it to use only the startup scripts I wanted, using this:
rpm2cpio foo.rpm | cpio -idmv --no-absolute-filenames
I couldn't find a ready file for /etc/sysconfig/oracle, so I created my own, based on the code in /etc/init.d/oracle:
#!/bin/bash
SET_ORACLE_KERNEL_PARAMETERS="yes";
START_ORACLE_DB_OCFS="no";
START_ORACLE_DB_OCM="no";
START_ORACLE_DB_GSD="no";
START_ORACLE_DB_LISTENER="yes";
START_ORACLE_DB="yes";
START_ORACLE_DB_APACHE="no";
START_ORACLE_DB_CMANAGER="no";
START_ORACLE_DB_AGENT="no";
START_ORACLE_DB_IFS="no";
START_ORACLE_DB_OID="no";
wrong, static path in "dbstart"
Posted: Sun Dec 04, 2005 12:46 pm
When starting oracle using "$ORACLE_HOME/bin/dbstart" that's coming with it, I received the following error:
Failed to auto-start Oracle Net Listene using /ade/vikrkuma_new/oracle/bin/tnslsnr
Obiously, the creator of "dbstart" whose username seems to be '
vikrkuma' has left us with this line here:
# Set this to bring up Oracle Net Listener
ORACLE_HOME_LISTNER=/ade/vikrkuma_new/oracle
by setting this variable to $ORACLE_HOME, everything's back in place where it belongs.
PHP, wwwrun and Oracle 10g
Posted: Wed Dec 07, 2005 6:32 am
By default, apache is running as user '
wwwrun', Oracle 10g has its default accessrights configured so that ONLY the oracle-user or members of the dba-group (specified during installation) can even list subdirs of $ORACLE_HOME.
Thus, you get the nice error:
oci_open_server: Error while trying to retrieve text for error ORA-12154"
although your ORACLE_HOME and ORACLE_SID is set properly.
I always thought that "dba" was short for "Database Administrat[or|ion]", but apparently it means "DB-access".
so:
add 'wwwrun' to your dba-group, restart apache (YES! that's important - and it took me almost 1 hour to find that out) and you're set.
