WRT54GL + Tomato = SSL ERROR / No https access
Posted: Sat Jan 11, 2020 6:28 am
After flashing my good old WRT54GL (v1.1) from original Linksys firmware (v4) to Tomato (1.28), I couldn't access the webinterface over https!
By default, Tomato's webinterface over HTTP is disabled...
Firefox (v71.0) refuses to connect, showing the following error message:
Chromium is even more silent and just says: "ERR_SSL_PROTOCOL_ERROR"
[WORKAROUND]
I haven't been able to re-generate a new certificate that firefox is happy with (or maybe it's Tomato's https-server?!).
BUT: You can enable the HTTP webinterface over Telnet
1) Login as root per telnet:
This changes the setting and stores it back in the non-volatile memory (nvram).
Afterwards reboot to apply the changes:
Now you should be able to access Tomato's webinterface over "http://" and deal with the SSL problem later.
Firefox 33.0 won't open a specific local application: Error code: sec_error_invalid_key
Unfortunately, you don't get infos or details about Tomato's certificate that seems to be "outdated" in a serious way.Secure Connection Failed
An error occurred during a connection to 192.168.1.1. SSL peer rejected a handshake message for unacceptable content.
Error code: SSL_ERROR_ILLEGAL_PARAMETER_ALERT
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the web site owners to inform them of this problem.
[WORKAROUND]
$ telnet 192.168.1.12) Enable HTTP:Trying 192.168.1.1...
Connected to 192.168.1.1.
Escape character is '^]'.
PBS1 login: root
$ nvram set http_enable=1
$ nvram commitAfterwards reboot to apply the changes:
$ rebootLinks:
