Linux & AMD B450: reading sensor values
Posted: Mon Apr 27, 2020 11:15 pm
Hardware:
So I manually loaded the kernel module:
Running "sensors" again now looks a bit better:
Making it persistent:
To load the kernel module automatically after reboot, copy the following contents into "/etc/modules-load.d/sensors.conf":
Running sensors-detect, answering everything with yes, or this:
Finds no sensors. Even after loading the nct6775 module:
- Mainboard: MSI Mortar B450M
- Controller Chip: Nuvoton NCT6797D
BUT: The [NCT6775 kernel driver](https://github.com/torvalds/linux/blob/ ... /nct6775.c) lists this controller chip as supported:k10temp-pci-00c3
Adapter: PCI adapter
Tdie: +39.9°C (high = +70.0°C)
Tctl: +49.9°C
Chip #vin #fan #pwm #temp chip IDs man ID
* nct6797d 14 7 7 2+6 0xd450 0xc1 0x5ca3Code: Select all
$ sudo modprobe -v nct6775Code: Select all
nct6797-isa-0a20
Adapter: ISA adapter
in0: +0.51 V (min = +0.00 V, max = +1.74 V)
in1: +1.01 V (min = +0.00 V, max = +0.00 V) ALARM
in2: +3.39 V (min = +0.00 V, max = +0.00 V) ALARM
in3: +3.38 V (min = +0.00 V, max = +0.00 V) ALARM
in4: +1.01 V (min = +0.00 V, max = +0.00 V) ALARM
in5: +0.18 V (min = +0.00 V, max = +0.00 V) ALARM
in6: +0.86 V (min = +0.00 V, max = +0.00 V) ALARM
in7: +3.38 V (min = +0.00 V, max = +0.00 V) ALARM
in8: +3.33 V (min = +0.00 V, max = +0.00 V) ALARM
in9: +1.84 V (min = +0.00 V, max = +0.00 V) ALARM
in10: +0.00 V (min = +0.00 V, max = +0.00 V)
in11: +0.62 V (min = +0.00 V, max = +0.00 V) ALARM
in12: +1.15 V (min = +0.00 V, max = +0.00 V) ALARM
in13: +0.69 V (min = +0.00 V, max = +0.00 V) ALARM
in14: +1.54 V (min = +0.00 V, max = +0.00 V) ALARM
fan1: 0 RPM (min = 0 RPM)
fan2: 944 RPM (min = 0 RPM)
fan3: 870 RPM (min = 0 RPM)
fan4: 0 RPM (min = 0 RPM)
fan5: 0 RPM (min = 0 RPM)
SYSTIN: +39.0°C (high = +80.0°C, hyst = +75.0°C) sensor = CPU diode
CPUTIN: +35.0°C (high = +115.0°C, hyst = +90.0°C) sensor = thermistor
AUXTIN0: +33.5°C (high = +115.0°C, hyst = +90.0°C) sensor = thermistor
AUXTIN1: -128.0°C sensor = thermistor
AUXTIN2: +48.0°C sensor = thermistor
AUXTIN3: -3.0°C sensor = thermistor
SMBUSMASTER 0: +50.0°C
PCH_CHIP_CPU_MAX_TEMP: +0.0°C
PCH_CHIP_TEMP: +0.0°C
PCH_CPU_TEMP: +0.0°C
intrusion0: ALARM
intrusion1: ALARM
beep_enable: disabledTo load the kernel module automatically after reboot, copy the following contents into "/etc/modules-load.d/sensors.conf":
# Module to support NUVOTON NCT6797D controller chip:
nct6775Links:
- Bogus k10temp readings for Ryzen 5 2600? (on level1techs.com)
- What is the SMBUSMASTER in a Ryzen machine and why is it so hot? (Reddit)
- Linux: How to load a kernel module automatically at boot time (by Vivek Gite on nixCraft)
$ sudo sensors-detect --autoSorry, no sensors were detected.
Either your system has no sensors, or they are not supported, or
they are connected to an I2C or SMBus adapter that is not
supported. If you find out what chips are on your board, check
http://www.lm-sensors.org/wiki/Devices for driver status.
