PHP7 Notice: "A non well formed numeric value encountered"
Posted: Sun Apr 11, 2021 12:18 am
I'm checking how much memory PHP has free to use, before further execution: usually returns a number with a size modifier character, like: "128M"
Before PHP7 (7.3?), php would just use that string as-is, ignore the non-numeric part, when used in a calculation.
This seems to have changed and now I get the following warning:
There's an example for converting a php.ini value like this to a number in PHP docs for "ini_get()", but It seems to suffer from the same new PHP7 stricter-ness
So I've changed the first lines to this:
I lowercase the ini value first, then extract the last character - and then remove any of the letters G, M or K (in lowercase) and store the number-only in "$val".
Now it works without warnings:
ini_get('memory limit')
PHP Notice: A non well formed numeric value encountered in /opt/dva-profession/devel/trunk/bin/include/ArchiveStructure.php on line 2372
$val = trim(strtolower($val));
$last = $val[strlen($val)-1];
$val = rtrim($val, "gmk");
* Converts a PHP config value data size with a modifier character to a
* numeric byte value.
* Code is an exact copy from:
* https://www.php.net/manual/en/function.ini-get.php
public static function return_bytes($val) {
switch($last) {
// The 'G' modifier is available since PHP 5.1.0
case 'g':
$val *= 1024;
case 'm':
$val *= 1024;
case 'k':
$val *= 1024;
return $val;
