GeForce 3060 on Xubuntu 22.04.3
Posted: Tue Jan 23, 2024 12:47 pm
Installing an NVIDIA GeForce RTX3060 (MSI-model) on an MSI B450M Mortar Max mainboard on Xubuntu 22.04.3.
Requires proprietary drivers (at the moment), but works.
1) First boot halted on "EZ Debug LED" VGA.
2) Cleared CMOS, then tried again: GPU works, system boots.
3) Xubuntu boots, but has wide-stretched low-resolution (1024x768 (4:3) stretched to 16:9) graphics fallback look.
4) Ubuntu "Additional Drivers" lists the NVIDIA (proprietary) options, but they're grayed out.
5) Running `sudo ubuntu-drivers install` downloaded and installed the nvidia-535 drivers (proprietary) automatically.
6) Reboot: Works.
"lscpi" reports:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following packages were automatically installed and are no longer required:
gir1.2-snapd-1 libflashrom1 libftdi1-2 libllvm13
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libnvidia-cfg1-535 libnvidia-common-535 libnvidia-compute-535
libnvidia-compute-535:i386 libnvidia-decode-535
libnvidia-decode-535:i386 libnvidia-encode-535
libnvidia-encode-535:i386 libnvidia-extra-535 libnvidia-fbc1-535
libnvidia-fbc1-535:i386 libnvidia-gl-535 libnvidia-gl-535:i386
linux-modules-nvidia-535-5.15.0-91-generic
linux-objects-nvidia-535-5.15.0-91-generic
nvidia-compute-utils-535 nvidia-firmware-535-535.154.05
nvidia-kernel-common-535 nvidia-kernel-source-535 nvidia-utils-535
xserver-xorg-video-nvidia-535
The following packages will be REMOVED:
libnvidia-cfg1-390 libnvidia-common-390 libnvidia-compute-390
libnvidia-compute-390:i386 libnvidia-decode-390
libnvidia-decode-390:i386 libnvidia-encode-390
libnvidia-encode-390:i386 libnvidia-fbc1-390
libnvidia-fbc1-390:i386 libnvidia-gl-390 libnvidia-gl-390:i386
libnvidia-ifr1-390 libnvidia-ifr1-390:i386
linux-modules-nvidia-390-5.15.0-91-generic
linux-modules-nvidia-390-generic nvidia-compute-utils-390
nvidia-driver-390 nvidia-kernel-common-390
nvidia-kernel-source-390 nvidia-utils-390
xserver-xorg-video-nvidia-390
The following NEW packages will be installed:
linux-modules-nvidia-535-generic
nvidia-compute-utils-535 nvidia-driver-535
nvidia-firmware-535-535.154.05 nvidia-kernel-common-535
0 upgraded, 23 newly installed, 22 to remove and 26 not upgraded.
Need to get 462 MB of archives.
After this operation, 910 MB of additional disk space will be used.
Get:1 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 libnvidia-cfg1-535 amd64 535.154.05-0ubuntu0.22.04.1 [110 kB]
Get:2 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 libnvidia-common-535 all 535.154.05-0ubuntu0.22.04.1 [16,5 kB]
Get:3 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted i386 libnvidia-compute-535 i386 535.154.05-0ubuntu0.22.04.1 [40,6 MB]
Get:4 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 libnvidia-compute-535 amd64 535.154.05-0ubuntu0.22.04.1 [40,7 MB]
Get:5 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 libnvidia-decode-535 amd64 535.154.05-0ubuntu0.22.04.1 [1.893 kB]
Get:6 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted i386 libnvidia-decode-535 i386 535.154.05-0ubuntu0.22.04.1 [2.215 kB]
Get:7 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted i386 libnvidia-encode-535 i386 535.154.05-0ubuntu0.22.04.1 [108 kB]
Get:8 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 libnvidia-encode-535 amd64 535.154.05-0ubuntu0.22.04.1 [99,1 kB]
Get:9 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 libnvidia-extra-535 amd64 535.154.05-0ubuntu0.22.04.1 [73,4 kB]
Get:10 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 libnvidia-fbc1-535 amd64 535.154.05-0ubuntu0.22.04.1 [57,0 kB]
Get:11 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted i386 libnvidia-fbc1-535 i386 535.154.05-0ubuntu0.22.04.1 [62,5 kB]
Get:12 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted i386 libnvidia-gl-535 i386 535.154.05-0ubuntu0.22.04.1 [35,4 MB]
Get:13 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 libnvidia-gl-535 amd64 535.154.05-0ubuntu0.22.04.1 [195 MB]
Get:14 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 linux-objects-nvidia-535-5.15.0-91-generic amd64 5.15.0-91.101+2 [58,2 MB]
Get:15 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 nvidia-firmware-535-535.154.05 amd64 535.154.05-0ubuntu0.22.04.1 [39,6 MB]
Get:16 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 nvidia-kernel-common-535 amd64 535.154.05-0ubuntu0.22.04.1 [212 kB]
Get:17 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 linux-modules-nvidia-535-5.15.0-91-generic amd64 5.15.0-91.101+2 [16,1 kB]
Get:18 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 linux-modules-nvidia-535-generic amd64 5.15.0-91.101+2 [14,4 kB]
Get:19 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 nvidia-compute-utils-535 amd64 535.154.05-0ubuntu0.22.04.1 [124 kB]
Get:20 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 nvidia-kernel-source-535 amd64 535.154.05-0ubuntu0.22.04.1 [45,2 MB]
Get:21 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 nvidia-utils-535 amd64 535.154.05-0ubuntu0.22.04.1 [414 kB]
Get:22 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 xserver-xorg-video-nvidia-535 amd64 535.154.05-0ubuntu0.22.04.1 [1.599 kB]
Get:23 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 nvidia-driver-535 amd64 535.154.05-0ubuntu0.22.04.1 [488 kB]
Fetched 462 MB in 1min 19s (5.834 kB/s)
Preconfiguring packages ...
(Reading database ... 187756 files and directories currently installed.)
Removing nvidia-driver-390 (390.157-0ubuntu0.22.04.2) ...
Removing xserver-xorg-video-nvidia-390 (390.157-0ubuntu0.22.04.2) ...
Removing libnvidia-cfg1-390:amd64 (390.157-0ubuntu0.22.04.2) ...
Removing libnvidia-ifr1-390:amd64 (390.157-0ubuntu0.22.04.2) ...
Removing libnvidia-gl-390:amd64 (390.157-0ubuntu0.22.04.2) ...
Removing libnvidia-ifr1-390:i386 (390.157-0ubuntu0.22.04.2) ...
Removing libnvidia-gl-390:i386 (390.157-0ubuntu0.22.04.2) ...
Removing libnvidia-common-390 (390.157-0ubuntu0.22.04.2) ...
Removing libnvidia-encode-390:i386 (390.157-0ubuntu0.22.04.2) ...
Removing libnvidia-decode-390:i386 (390.157-0ubuntu0.22.04.2) ...
Removing libnvidia-compute-390:i386 (390.157-0ubuntu0.22.04.2) ...
Removing libnvidia-encode-390:amd64 (390.157-0ubuntu0.22.04.2) ...
Removing libnvidia-decode-390:amd64 (390.157-0ubuntu0.22.04.2) ...
Removing nvidia-utils-390 (390.157-0ubuntu0.22.04.2) ...
Removing libnvidia-fbc1-390:i386 (390.157-0ubuntu0.22.04.2) ...
Removing libnvidia-fbc1-390:amd64 (390.157-0ubuntu0.22.04.2) ...
Removing linux-modules-nvidia-390-generic (5.15.0-91.101+2) ...
Removing linux-modules-nvidia-390-5.15.0-91-generic (5.15.0-91.101+2) ...
linux-image-nvidia-5.15.0-91-generic: removing .ko files
Removing nvidia-compute-utils-390 (390.157-0ubuntu0.22.04.2) ...
Removing nvidia-kernel-common-390 (390.157-0ubuntu0.22.04.2) ...
update-initramfs: deferring update (trigger activated)
Removing nvidia-kernel-source-390 (390.157-0ubuntu0.22.04.2) ...
Removing libnvidia-compute-390:amd64 (390.157-0ubuntu0.22.04.2) ...
Selecting previously unselected package libnvidia-cfg1-535:amd64.
(Reading database ... 187198 files and directories currently installed.)
Preparing to unpack .../00-libnvidia-cfg1-535_535.154.05-0ubuntu0.22.04.1_amd64.deb ...
Unpacking libnvidia-cfg1-535:amd64 (535.154.05-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-common-535.
Preparing to unpack .../01-libnvidia-common-535_535.154.05-0ubuntu0.22.04.1_all.deb ...
Unpacking libnvidia-common-535 (535.154.05-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-compute-535:i386.
Preparing to unpack .../02-libnvidia-compute-535_535.154.05-0ubuntu0.22.04.1_i386.deb ...
Unpacking libnvidia-compute-535:i386 (535.154.05-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-compute-535:amd64.
Preparing to unpack .../03-libnvidia-compute-535_535.154.05-0ubuntu0.22.04.1_amd64.deb ...
Unpacking libnvidia-compute-535:amd64 (535.154.05-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-decode-535:amd64.
Preparing to unpack .../04-libnvidia-decode-535_535.154.05-0ubuntu0.22.04.1_amd64.deb ...
Unpacking libnvidia-decode-535:amd64 (535.154.05-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-decode-535:i386.
Preparing to unpack .../05-libnvidia-decode-535_535.154.05-0ubuntu0.22.04.1_i386.deb ...
Unpacking libnvidia-decode-535:i386 (535.154.05-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-encode-535:i386.
Preparing to unpack .../06-libnvidia-encode-535_535.154.05-0ubuntu0.22.04.1_i386.deb ...
Unpacking libnvidia-encode-535:i386 (535.154.05-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-encode-535:amd64.
Preparing to unpack .../07-libnvidia-encode-535_535.154.05-0ubuntu0.22.04.1_amd64.deb ...
Unpacking libnvidia-encode-535:amd64 (535.154.05-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-extra-535:amd64.
Preparing to unpack .../08-libnvidia-extra-535_535.154.05-0ubuntu0.22.04.1_amd64.deb ...
Unpacking libnvidia-extra-535:amd64 (535.154.05-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-fbc1-535:amd64.
Preparing to unpack .../09-libnvidia-fbc1-535_535.154.05-0ubuntu0.22.04.1_amd64.deb ...
Unpacking libnvidia-fbc1-535:amd64 (535.154.05-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-fbc1-535:i386.
Preparing to unpack .../10-libnvidia-fbc1-535_535.154.05-0ubuntu0.22.04.1_i386.deb ...
Unpacking libnvidia-fbc1-535:i386 (535.154.05-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-gl-535:amd64.
Preparing to unpack .../11-libnvidia-gl-535_535.154.05-0ubuntu0.22.04.1_amd64.deb ...
Unpacking libnvidia-gl-535:amd64 (535.154.05-0ubuntu0.22.04.1) ...
Selecting previously unselected package libnvidia-gl-535:i386.
Preparing to unpack .../12-libnvidia-gl-535_535.154.05-0ubuntu0.22.04.1_i386.deb ...
Unpacking libnvidia-gl-535:i386 (535.154.05-0ubuntu0.22.04.1) ...
Selecting previously unselected package linux-objects-nvidia-535-5.15.0-91-generic.
Preparing to unpack .../13-linux-objects-nvidia-535-5.15.0-91-generic_5.15.0-91.101+2_amd64.deb ...
Unpacking linux-objects-nvidia-535-5.15.0-91-generic (5.15.0-91.101+2) ...
Selecting previously unselected package nvidia-firmware-535-535.154.05.
Preparing to unpack .../14-nvidia-firmware-535-535.154.05_535.154.05-0ubuntu0.22.04.1_amd64.deb ...
Unpacking nvidia-firmware-535-535.154.05 (535.154.05-0ubuntu0.22.04.1) ...
Selecting previously unselected package nvidia-kernel-common-535.
Preparing to unpack .../15-nvidia-kernel-common-535_535.154.05-0ubuntu0.22.04.1_amd64.deb ...
Unpacking nvidia-kernel-common-535 (535.154.05-0ubuntu0.22.04.1) ...
Selecting previously unselected package linux-modules-nvidia-535-5.15.0-91-generic.
Preparing to unpack .../16-linux-modules-nvidia-535-5.15.0-91-generic_5.15.0-91.101+2_amd64.deb ...
Unpacking linux-modules-nvidia-535-5.15.0-91-generic (5.15.0-91.101+2) ...
Selecting previously unselected package linux-modules-nvidia-535-generic.
Preparing to unpack .../17-linux-modules-nvidia-535-generic_5.15.0-91.101+2_amd64.deb ...
Unpacking linux-modules-nvidia-535-generic (5.15.0-91.101+2) ...
Selecting previously unselected package nvidia-compute-utils-535.
Preparing to unpack .../18-nvidia-compute-utils-535_535.154.05-0ubuntu0.22.04.1_amd64.deb ...
Unpacking nvidia-compute-utils-535 (535.154.05-0ubuntu0.22.04.1) ...
Selecting previously unselected package nvidia-kernel-source-535.
Preparing to unpack .../19-nvidia-kernel-source-535_535.154.05-0ubuntu0.22.04.1_amd64.deb ...
Unpacking nvidia-kernel-source-535 (535.154.05-0ubuntu0.22.04.1) ...
Selecting previously unselected package nvidia-utils-535.
Preparing to unpack .../20-nvidia-utils-535_535.154.05-0ubuntu0.22.04.1_amd64.deb ...
Unpacking nvidia-utils-535 (535.154.05-0ubuntu0.22.04.1) ...
Selecting previously unselected package xserver-xorg-video-nvidia-535.
Preparing to unpack .../21-xserver-xorg-video-nvidia-535_535.154.05-0ubuntu0.22.04.1_amd64.deb ...
Unpacking xserver-xorg-video-nvidia-535 (535.154.05-0ubuntu0.22.04.1) ...
Selecting previously unselected package nvidia-driver-535.
Preparing to unpack .../22-nvidia-driver-535_535.154.05-0ubuntu0.22.04.1_amd64.deb ...
Unpacking nvidia-driver-535 (535.154.05-0ubuntu0.22.04.1) ...
Setting up nvidia-firmware-535-535.154.05 (535.154.05-0ubuntu0.22.04.1) ...
Setting up libnvidia-fbc1-535:amd64 (535.154.05-0ubuntu0.22.04.1) ...
Setting up libnvidia-fbc1-535:i386 (535.154.05-0ubuntu0.22.04.1) ...
Setting up nvidia-kernel-common-535 (535.154.05-0ubuntu0.22.04.1) ...
Created symlink /etc/systemd/system/systemd-hibernate.service.wants/nvidia-hibernate.service → /lib/systemd/system/nvidia-hibernate.service.
Created symlink /etc/systemd/system/systemd-suspend.service.wants/nvidia-resume.service → /lib/systemd/system/nvidia-resume.service.
Created symlink /etc/systemd/system/systemd-hibernate.service.wants/nvidia-resume.service → /lib/systemd/system/nvidia-resume.service.
Created symlink /etc/systemd/system/systemd-suspend.service.wants/nvidia-suspend.service → /lib/systemd/system/nvidia-suspend.service.
Setting up libnvidia-common-535 (535.154.05-0ubuntu0.22.04.1) ...
Setting up libnvidia-extra-535:amd64 (535.154.05-0ubuntu0.22.04.1) ...
Setting up libnvidia-cfg1-535:amd64 (535.154.05-0ubuntu0.22.04.1) ...
Setting up nvidia-kernel-source-535 (535.154.05-0ubuntu0.22.04.1) ...
Setting up libnvidia-gl-535:amd64 (535.154.05-0ubuntu0.22.04.1) ...
Setting up libnvidia-gl-535:i386 (535.154.05-0ubuntu0.22.04.1) ...
Setting up libnvidia-compute-535:amd64 (535.154.05-0ubuntu0.22.04.1) ...
Setting up libnvidia-compute-535:i386 (535.154.05-0ubuntu0.22.04.1) ...
Setting up linux-objects-nvidia-535-5.15.0-91-generic (5.15.0-91.101+2) ...
Setting up nvidia-utils-535 (535.154.05-0ubuntu0.22.04.1) ...
Setting up nvidia-compute-utils-535 (535.154.05-0ubuntu0.22.04.1) ...
Warning: The home dir /nonexistent you specified can't be accessed: No such file or directory
Adding system user `nvidia-persistenced' (UID 117) ...
Adding new group `nvidia-persistenced' (GID 135) ...
Adding new user `nvidia-persistenced' (UID 117) with group `nvidia-persistenced' ...
Not creating home directory `/nonexistent'.
Setting up linux-modules-nvidia-535-5.15.0-91-generic (5.15.0-91.101+2) ...
linux-image-nvidia-5.15.0-91-generic: constructing .ko files
nvidia-drm.ko: OK
nvidia-modeset.ko: OK
nvidia-peermem.ko: OK
nvidia-uvm.ko: OK
nvidia.ko: OK
Setting up libnvidia-decode-535:amd64 (535.154.05-0ubuntu0.22.04.1) ...
Setting up libnvidia-decode-535:i386 (535.154.05-0ubuntu0.22.04.1) ...
Setting up xserver-xorg-video-nvidia-535 (535.154.05-0ubuntu0.22.04.1) ...
Setting up linux-modules-nvidia-535-generic (5.15.0-91.101+2) ...
Setting up libnvidia-encode-535:amd64 (535.154.05-0ubuntu0.22.04.1) ...
Setting up libnvidia-encode-535:i386 (535.154.05-0ubuntu0.22.04.1) ...
Setting up nvidia-driver-535 (535.154.05-0ubuntu0.22.04.1) ...
Processing triggers for libc-bin (2.35-0ubuntu3.6) ...
Processing triggers for man-db (2.10.2-1) ...
Processing triggers for initramfs-tools (0.140ubuntu13.4) ...
update-initramfs: Generating /boot/initrd.img-5.15.0-91-generic
Processing triggers for linux-image-5.15.0-91-generic (5.15.0-91.101) ...
/etc/kernel/postinst.d/dkms:
* dkms: running auto installation service for kernel 5.15.0-91-generic
...done.
/etc/kernel/postinst.d/initramfs-tools:
/etc/kernel/postinst.d/zz-update-grub:
Sourcing file `/etc/default/grub'
Sourcing file `/etc/default/grub.d/init-select.cfg'
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-5.15.0-91-generic
Found initrd image: /boot/initrd.img-5.15.0-91-generic
Found linux image: /boot/vmlinuz-5.15.0-43-generic
Found initrd image: /boot/initrd.img-5.15.0-43-generic
Memtest86+ needs a 16-bit boot, that is not available on EFI, exiting
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
Adding boot menu entry for UEFI Firmware Settings ...
6) Reboot: Works.
"lscpi" reports:
$ lspci -k | grep -EA3 'VGA|3D|Display'
26:00.0 VGA compatible controller: NVIDIA Corporation GA104 [GeForce RTX 3060] (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] Device 397d
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
26:00.1 Audio device: NVIDIA Corporation GA104 High Definition Audio Controller (rev a1)
$ sudo ubuntu-drivers install
nvidia-drm.ko: OK
nvidia-uvm.ko: OK
nvidia.ko: OK
...done.
