Perl: "Linux::Input" and problem with IO redirecti
Posted: Tue Feb 21, 2006 3:42 pm
When polling events using the Perl module "Linux::Input", the default output gets shifted to something else. This results in problems when redirecting the output of this script.
Example:
#!/usr/bin/perl
use Linux::Input::Joystick;
my $js = Linux::Input::Joystick->new("/dev/js0");
while (1) {
  my @event = $js->poll(0.01);
  printf("ding dong\n");
$> ./myscript.pl
outputs "dingdong"
$> ./myscript.pl > test.txt
...leaves us with an empty (0 byte size) test.txt.
According to a friend of mine, the "selector" in "Linux::Input" shifts the default output to something else during polling, but doesn't set it back.
#!/usr/bin/perl
while (1) {
  printf STDOUT "ding dong\n";
redirecting the output of this version to "test.txt" works fine.
NOTE: Actually, I'm not really sure if that's a bug in Linux::Input or not.
I was wrong - Problem still NOT fixed
Posted: Tue Feb 21, 2006 4:21 pm
I'm sorry, but simply using print STDOUT "blabla..\n" didn't solve this problem.
Even more confusing is that filehandles seem to be broken at all when calling "$js->poll()":
#!/usr/bin/perl
print "hello\n";
open $fh, ">test.txt" or die "broken: $!\n";
while (1) {
  print $fh ".\n";
  select STDOUT;
  print STDOUT ":\n";
This outputs a lot of ":" and should write "." to test.txt, but it doesn't.
Hahaaa! I think I've solved it!
Posted: Tue Feb 21, 2006 5:15 pm
[MAYBE the PROBLEM]
I think that the problem is not really with Linux::Input or IOSelect - but it's my infinite loop that's causing a problem!
Because my main intention was to read input from a joystick device, I did "while (1)" and killed it with Ctrl+C. Unfortunately stdout was not flushed before, so my "print" outputs stayed in the buffer which never got flushed.
[MAYBE the SOLUTION]
If my perl would be better, I'd flush the buffer to STDOUT manually after each incoming joystick event, but that's the only thing I found for flushing:
autoflush STDOUT 1;
I've added this to my code and now it seems to work. whooopee!!
