Teamspeak 2 Server not starting
Posted: Wed Apr 12, 2006 10:11 pm
We recently had trouble with our teamspeak2 installation on our LFS (Linux from Scratch) Server. I created a user/group with NO privileges at all, 'cept for the ts2 directory. Even tho this worked a hundred times on all flavors of linux', this time i got a nasty error:
Google did not help much on the 'EInOutError: I/O error 13' - even tho there were like, two threads with similar problems, it was not the same solution. One of those threads gave the hint to solve this problem, tho
In our case, the '/dev/null' access rights were not proper configured. TS2 needs this device to work, but it was set to chmod 660. A simple 'chmod 666 /dev/null' did the trick - up and running, happy voice chatting!
Another solution to this and similar errors: make sure the user who runs TS2 has appropriate rights in the teamspeak2 directory and its subdirectories. A common mistake is to chmod the teamspeak2 directory without the recursive flag, so the subdirs are not chown'ed/chmod'ed.
[Notes]
I read about this for a minute, and appearently it is not common for /dev/null to be set to 660. I could not find anything about any security risks caused by setting the device to those access rights. If someone knows better, drop a line.
-------------- log started at 30-03-06 19:34 -------------
30-03-06 19:34:26,ALL,Info,server, Server init initialized
30-03-06 19:34:26,ERROR,Info,server, EInOutError: I/O error 13
--------------- log ended at 30-03-06 19:34 --------------
[Notes]
