Asus A8R32 MVP Deluxe won't boot
Posted: Mon Jul 10, 2006 2:22 pm
I built my new box on the base of a Asus A8R32 MVP Deluxe motherboard. Since the gfx board and RAM was not delivered yet, i just put in a single DIMM (Single RAM only works on RAM slot B1!) DDR 266 and a PCI gfx board, to see if it would actually boot up or if the delivered motherboard was broken.
The Asus A8R32 MVP Deluxe does not boot from PCI gfx cards. As soon as i had the PCI-E gfx card and put that one in, it came up like a charm. Its a crossfire-ready board, so make sure you put the gfx board in the blue (primary) PCI-E slot. As mentioned above, also doublecheck that the RAM - if you are using one single dimm, that is - is put into the first slot of the second bank. Its called "B1" and is the blue slot on the B-labeled ram-bank.
