Shuttle ST20G5 NIC Drivers linux
Posted: Thu Aug 24, 2006 3:49 pm
When installing devil linux on a XPC Shuttle ST20G5, i had trouble finding the correct network driver for the on-board ethernet card.
The correct driver for the on-board device is the 'tg3' module. This stands for (Broadcom) Tigon 3. After using the devil linux setup / manually insert the driver, the interface should be up and running in no time
