OpenVPN: Cannot open TUN/TAP dev
Posted: Thu Aug 31, 2006 10:34 pm
OpenVPN refused to start. In the logs I found this errormessage:
The kernel was missing TUN/TAP device support.
Using "make menuconfig", you can find it in:
Even "openvpn --mktun --dev tun0" didn't help any.Thu Aug 31 22:01:25 2006 OpenVPN 2.1_beta14 i686-pc-linux [SSL] [LZO2] [EPOLL] built on Aug 31 2006
Thu Aug 31 22:01:25 2006 Diffie-Hellman initialized with 1024 bit key
Thu Aug 31 22:01:25 2006 TLS-Auth MTU parms [ L:1542 D:138 EF:38 EB:0 ET:0 EL:0 ]
Thu Aug 31 22:01:25 2006 Note: Cannot open TUN/TAP dev /dev/net/tun: No such file or directory (errno=2)
Thu Aug 31 22:01:25 2006 Note: Attempting fallback to kernel 2.2 TUN/TAP interface
Thu Aug 31 22:01:25 2006 Cannot allocate TUN/TAP dev dynamically
Thu Aug 31 22:01:25 2006 Exiting
When compiling it as a module, it's in "/lib/modules/KERNELVERSION/kernel/drivers/net/tun.ko""Network device support" > "Universal TUN/TAP device driver support"
