After changing date/time on my server, I received this errormessage when executing sudo:
[SOLUTION]sudo: timestamp too far in the future
Remove any references to previous sudo executions from your user.
(Unfortunately you have to have an enabled root account to do this)
su root
rm -R /var/run/sudo/$LOGNAME/*
Set your date/time to some time AFTER the one sudo is expecting.
run "sudo -k" to clear the timestamp.
Set date/time back to what it should be.
-- OR --
Open another terminal (Alt+Fsomething) and log in as your non-root user.
Reset the timestamps of the sudo files to -now-:
sudo touch /var/run/sudo/$LOGNAME/*
[ADDITIONAL Information]
The problem seems to be caused by wrong timestamps of the files in /var/run/sudo/$LOGNAME (where $LOGNAME is the username you're currently logged in as).
Further solutions, infos, can be found here.
