File system conversion Windows 2k XP
Posted: Sat Feb 24, 2007 9:40 pm
				Under W2k or XP you can use convert.exe to change the filesystem from FAT to NTFS, i.e. after convently partioning your disk with qparted.
This is easiely done in the shell with "convert". Now, mind that convert doesn't have a help switch. You must type "help convert" to see the options.
