Simple MySQL backup script
Posted: Mon Aug 13, 2007 10:23 am
I know, I know... There are already thousands and thousands of mysql backup scripts out there. So why do I post my own?
Because most of the other ready-available scripts are too complex and thus error prone if you only need a straightforward mysqldump.
You just supply it with "username:password@dbname" strings and it dumps and zips the database contents into a file.
#!/bin/bash
# @author: ^Rooker
# @date: 13.Aug.2007
# @license: GPL
# @description:
# This script should backup our local MySQL databases.
# @usage:
# $WIKI_DBS must contain login credentials for each database to be backed up.
# The syntax is: username:password@dbname
WIKI_DBS="user1:pass1@dbname1 user2:pass2@dbname2";
DEST_DIR="/mount/storage/backup"; # Destination directory for backup files
TIMESTAMP=`date +%Y%m%d_%H%M` # Current timestamp. Will be used in the filename.
SUFFIX="sql.bz2" # File suffix of backup dumps
for WIKI_DB in $WIKI_DBS; do
DB_NAME=`echo $WIKI_DB | sed -e "s/.*@//g"`
echo "Backing up \"$DB_NAME\"... "
LOGIN=${WIKI_DB/"@"/" "} # the database name has no prefix and only needs a space.
LOGIN=${LOGIN/":"/" --password="} # : marks the beginning of the password
LOGIN="--user="$LOGIN # The first word is the username, so prefix it with --user.
#echo "$LOGIN"
FILENAME=$DEST_DIR"/"$TIMESTAMP"-"$DB_NAME"."$SUFFIX
mysqldump $LOGIN | bzip2 -c > $FILENAME
done
