If you use Windows 2000, and can't get some old W95/W98 games to work, there might as well be a easy thing to try it with. Coming with servicepack 2 of W2K - check this out. Just get up the Start=>Run thing, and type:
regsvr32 c:\winnt\apppatch\slayerui.dll
You will get a message that the DLL has been successfully installed, and from now on got a new option if you edit .pif files: The compability mode. What does this help you with, well, examples:
Battlezone II:
If you run the setup.exe on the CD, W2K will close the setup with an error msg. Just make a .pif of the Setup on your Desktop, run it in W98 compability mode, and start the link. Wow! It works! Yay! Battlezone again, finally!
Vampire: the Masquerade - Redemption :
Same as with Battlezone, tho i found out its good to also run the game itself after installing it with an compability setting.
Maybe that helps someone, and since iam much into old games, i might as well bring a ton more tips on getting those to work. The next bigger msg will be about the VDMS Proggie, which helps you to emulate native DOS, Memory handling, load a native CDRom driver emulator, emulate an old Soundblaster, and so on. With that thing, you can get almost everything to work.
- Gil
Windows 2000: Compatibility Mode for Win95/98
... Screenshot
Tho this Windows Version is in German, i guess you get the point where you find the compatibility options when editing a link. As you can see, there is not only a W95 and 98, but also a Win NT compatibility setting.
Good stuff, this stuff
Stuttering Sound in DOSBox
We tried to get an old game running in DOSBox, but the digital sound (not MIDI!) was stuttering regardless of chosen Soundcard, IRQ or whatever.
DOSBox has a default of 3000 CPU cycles - after lowering that down to 1500 the sound ran smoothly.
Strangely, that value seems to be a problem during initialization of the program - so turning the value back to 3000 as soon as the game runs enhances playability a lot.
