Windows 2000: Compatibility Mode for Win95/98
Posted: Mon Sep 08, 2003 10:00 pm
If you use Windows 2000, and can't get some old W95/W98 games to work, there might as well be a easy thing to try it with. Coming with servicepack 2 of W2K - check this out. Just get up the Start=>Run thing, and type:
regsvr32 c:\winnt\apppatch\slayerui.dll
You will get a message that the DLL has been successfully installed, and from now on got a new option if you edit .pif files: The compability mode. What does this help you with, well, examples:
Battlezone II:
If you run the setup.exe on the CD, W2K will close the setup with an error msg. Just make a .pif of the Setup on your Desktop, run it in W98 compability mode, and start the link. Wow! It works! Yay! Battlezone again, finally!
Vampire: the Masquerade - Redemption :
Same as with Battlezone, tho i found out its good to also run the game itself after installing it with an compability setting.
Maybe that helps someone, and since iam much into old games, i might as well bring a ton more tips on getting those to work. The next bigger msg will be about the VDMS Proggie, which helps you to emulate native DOS, Memory handling, load a native CDRom driver emulator, emulate an old Soundblaster, and so on. With that thing, you can get almost everything to work.
- Gil
Battlezone II:
- Gil
