remote controlled PCs using IR
...non-electric cooling, modding old computer chassis to fit a new ATX board, Experimental stuff.
board layouts (and other soldering stuff) can be found at:
http://werkstatt.defconstudios.com/forum/werkstatt/viewtopic.php?t=121
Reason: Fixing outdated url: werkstatt.defconstudios.com
Transmitter quality
Currently, I am rather unhappy with the quality of the transmitter, since it is very intolerant regarding the positioning.
I am suspecting the rather "large" distance between sender and receiver (e.g. TV, DVD-player, ...) which is currently about 4m.
LED on transmitter
I'm not really sure, if this is supposed to be normal, but immediately after attaching the transmitter to the serial port, the LED is off.
After a few seconds it "fades in" and stays glowing.
Whenever an IR signal is sent, it pulse-flashes (I assume that THIS is normal)
Enhancing transmitter quality
Since I am not satisfied with the hit ratio of my transmitter, I am currently experimenting different improvement possibilities.
After analyzing signals coming from a standard remote (using 'irw'), I've discovered, that when pushing the button normally, at least 2 pulses are sent.
In combination with witnessing that using 'rc' with "SEND_START" + "SEND_STOP" + the 'sleep' command has higher hit ratio, I've tried a little script, which REALLY improved the hits (compared to "SEND_ONCE"):
remote="my_remote";
pause="250000"; #time in microseconds. 500000 is 1/2 second.
key=$2;
rc SEND_START $remote $key; usleep $pause
rc SEND_STOP $remote $key;
*sigh*
"thou shalt not reinvent the wheel..."
Just yesterday I've accidentially discovered, that it's possible to add
"min_repeat x" to the remote-control config file (e.g. lircd.conf) which does exactly the same thing - just better.
I've experimented a bit and found out that a value of 2 or 3 works fine.
